3rd memeber help!
Old Oct 4, 2011 | 11:34 PM
runs-on-4's Avatar
3rd memeber help!
picked up a new (to me) 3rd memeber. the ring has 37 teeth and the pinion has 9 making it a 4:11 and my old one has 41 and 10 making it 4:10.. also not sure how to tell if its out of a v-6 or not. could i runn this or will it cause a big problem
Old Oct 5, 2011 | 12:53 AM
dropzone's Avatar
Fossilized
4 cyl third has 2 spider gears, v6 has 4 spider gears
Old Oct 5, 2011 | 06:04 AM
badattitude's Avatar
toyota OEM 4.10 has the 41/10 setup
Aftermarket gears are 37/9
You can use the 37/9 = 4.11 third with a OEM front 4.10
I've actually driven a 4.10 front with a 4.11 rear on pavement in 4wd for about a 1/2 mile. It's fine.
I did go back to OEM 41/10 4.10 beacsue the OEM gears were quieter than the 37/9 gears. My diff guy just couldn't set up the 37/9. He could set up the 41/10.
Old Oct 5, 2011 | 06:09 AM
xxxtreme22r's Avatar
Toyota did make OEM 4.11's. IIRC they were never put into v6's either. I wanna say they only came in 1st gens and maybe even only 2wd's. But not sure on that.
Old Oct 5, 2011 | 08:02 AM
runs-on-4's Avatar
maybe this is a dumb question but what is iirc? and so i should be fine putting my spartin locker in the 4:11 3rd?
Old Oct 5, 2011 | 08:03 AM
IIRC = If I Recall Correctly. I don't see why the spartan wouldn't fit in there. As long as it's a 4cyl (2 pinion) spartan.
Old Oct 5, 2011 | 10:06 AM
runs-on-4's Avatar
another question, im trying to install the spartin and the ring has to come off but it has this clips around the bolts. do i just bend them down and hammer back up when i put it back on or is there something else?
Old Oct 5, 2011 | 10:29 AM
runs-on-4's Avatar
nevermind on that last question aha figured it out
Old Oct 5, 2011 | 10:40 AM
BigBluePile's Avatar
Read thru these.....: http://www.gearinstalls.com/
Old Oct 5, 2011 | 10:46 AM
runs-on-4's Avatar
i have been, i think i got it under control now aha
Old Oct 5, 2011 | 01:51 PM
runs-on-4's Avatar
is there some sort of trick to get the ring back on?
Old Oct 5, 2011 | 05:23 PM
Ugh........if it popped off it'll pop back on.
Old Oct 6, 2011 | 01:27 PM
runs-on-4's Avatar
anyone know the torque specs for the bearing cap bolts and ring bolts?
Old Oct 6, 2011 | 01:50 PM
it isn't listed in the fsm?
Old Oct 6, 2011 | 06:21 PM
runs-on-4's Avatar
im sure it is but i cant find mine...
Old Oct 6, 2011 | 08:31 PM
runs-on-4's Avatar
its not in my haynes book. anyone know a good source?
LittleUgly
15
Jan 2, 2020 01:30 PM
Flightguy
Oct 2, 2015 05:34 PM
voiddweller
Oct 2, 2015 07:47 AM
Rickstwowheels
Sep 29, 2015 02:23 PM
charlie_fong
Sep 27, 2015 10:06 PM
