While cranking the coolant gets blown from the radiator
Old Jun 15, 2011 | 06:07 PM
Z's Confederate Toy's Avatar
I just recently put a used head on my truck because my last one warped. When I went to start it up the coolant gets blown from my radiator while I was cranking on it. The only thing I can figure is that there is a crack in the cylinder wall. But while I had the head off I looked at the cylinders and they seemed fine. They still had the cross hatching and looked pretty decent. The only thing I could think is there is something wrong with my head. Yall have any thoughts?
Old Jun 15, 2011 | 07:34 PM
windedwalrus's Avatar
did you turn the motor over and check all of the cylinder walls? sounds like you have a cracked block or the head gasket on wrong.
Old Jun 15, 2011 | 07:47 PM
I did look at the cyl walls and they looked good. My dad is thinkin its the HG.
Old Jun 15, 2011 | 07:52 PM
yotajordan14's Avatar
just make sure your water jackets dont have any kind of dowell shaped pins of that nature, your getting air somewhere, you can do a compresion test on your coolant system which i think autozone has that on loan a tool, or check each cylinder with a compresion tester turn the engine and if your spray coolant i woul take off the head and examine for any misshaps, i would use about 10-13psi with this test also, but keep an aye out for your liquids for any contamination
Old Jun 15, 2011 | 07:54 PM
justin_4runner's Avatar
do u have a thermostat in? could be that the water pump is just pushing it threw and if u dont have a thermostat in it wont stop it from pushing it threw and out. just a thought.
Old Jun 16, 2011 | 02:58 PM
James Woods's Avatar
From my experience when this happens it is usually a head gasket or a warped head, I think it would have to be a pretty big crack in the cylinder to shoot coolant.
Old Jun 16, 2011 | 03:41 PM
Also with a crack in the cylinder big enuff to blow coolant out of the rad it would also end up in the crank case.
Old Jun 16, 2011 | 03:58 PM
85TurboRunner's Avatar
I'd think more a cracked head then block.
sandyota
Feb 4, 2021 11:16 AM
the1998sr5
15
Jul 14, 2020 08:35 PM
94 Newbie
Aug 6, 2015 10:33 AM
Logz808
Jul 26, 2015 07:09 AM
Poncho0206
Jul 10, 2015 06:21 PM
