Oil Leak 22RE
Old Jul 22, 2011 | 08:53 PM
bryonb's Avatar
Oil Leak 22RE
I have a small oil leak I'm trying to figure out. Replaced the gasket for the rear cylinder head plate to find out that only coolant goes through there. I'm thinking and hoping that the leak is coming from the rear half moon gasket below the valve cover. I'm going to use some RTV silicone gasket to seal it up. It's rated for 500 deg will that be good?
Thanks
Old Jul 22, 2011 | 09:01 PM
4x4climber's Avatar
get a new gasket set for 15bucks at autozone. And use rtv on the corners of the half moons.
Old Jul 22, 2011 | 09:09 PM
bryonb's Avatar
The rebuild only has 3000 miles on it. Do I still need to replace or just seal.
Old Jul 22, 2011 | 10:15 PM
4x4climber's Avatar
if ur taking it off replace it... your trying to prevent oil leaks right... whats 15 bucks?
and also put some on the undersides of the half moons. just a little bead
Colington
Mar 8, 2020 09:51 AM
Eggslinger
Jun 8, 2019 03:32 PM
jakebarrett
Jul 10, 2015 07:15 PM
Coreyr384
Jul 10, 2015 11:13 AM
87blyota
Jul 10, 2015 04:31 AM
