5th GEAR POPS OUT.
Old Sep 3, 2011 | 10:38 PM
crawlaholic's Avatar
5th GEAR POPS OUT.
I got an 86 4runner that pops out of 5th gear when decelerating or when I'm going down on a hill. It won't pop out when driving on level areas or accelerating. My engine mount and transmission seem to be ok.
The tranny has just been rebuild two years ago. Can someone help if anyone out there is familiar with my problem. Your help will be greatly appreciated.
Old Sep 3, 2011 | 11:35 PM
wyoming9's Avatar
Smile
Bad bearing in the rebuild kit!!
I had one didn`t make it near as long most likely same transmission
The bearing starts to wear just enough to allow things to loosen up once the load is off the transmission.
You can pull it now and rebuild or run it till it quits and hope it is not in a bad place traffic wise.
Old Sep 6, 2011 | 01:00 AM
I appreciate the info. Really disappointed to think that I might have to just get a new tranny. I probably won't go through the rebuild again. Thanks again for your help.
Old Sep 7, 2011 | 07:27 PM
crashnburn80's Avatar
Double check your tranny fluid level, low fluid can cause a similar behavior, though the damage may be done.
Old Sep 7, 2011 | 07:51 PM
rattlers's Avatar
hello, did you change the shifter seat and the shifter end cap, not sure if that would cause the prob your having , but its a start if they have never been changed before , I got my parts at toyota they had them in stock , I cant remember the price I think under $20 for both..
http://www.off-road.com/trucks-4x4/t...ent-18543.html
smthwsn357
May 1, 2024 07:28 AM
young buck
18
Aug 27, 2018 02:40 PM
mskalmus
May 28, 2017 07:51 AM
msane99
Jul 17, 2015 10:13 AM
Jnkml
Jul 6, 2015 01:20 PM
