odometer runs without truck moving?
Old Aug 8, 2011 | 09:15 AM
yodskee84's Avatar
I have recently swapped cabs on my 84 pickup due to a four wheeling accident and now when I start the engine the odometer starts rolling miles on while im not moving? Does anyone have any idea on what could cause this? Any input would help... Thanks.
Old Aug 8, 2011 | 05:04 PM
Jasper 83's Avatar
I'm not sure but that's bad for resale value haha. Does the speedo move too or just the odometer?
Old Aug 9, 2011 | 02:53 PM
swampfox's Avatar
If it is running backwards you are going to die. At least that is what happens in Stephen king movies. Christine is back.
Old Aug 11, 2011 | 10:57 AM
swampfox's Avatar
Did you find the cause of the problem yet ? On a truck with a mechanical speedometer the only thing in there that can move the odometer is the speedometer cable. If it was an electronic speedometer it could be a short . Other than that I stumped.
Old Aug 11, 2011 | 10:59 AM
xxxtreme22r's Avatar
subscribed as I got to know the answer to this.
Old Aug 11, 2011 | 11:12 AM
BMcEL's Avatar
This is awesome...subscribed.
Old Aug 11, 2011 | 11:55 AM
blake.nemitz's Avatar
no idea. do you have an other cluster to try?
Old Aug 11, 2011 | 07:40 PM
peow130's Avatar
sounds like a short causing the odometer to constantly get some kind of signal..
Find out how much the odometer is moving per minute?
Possible stuck relay? Bad sending unit?
Old Aug 11, 2011 | 07:49 PM
4Crawler's Avatar
So with the cab swap, what all was swapped? Was the speedo/odo the original one? If so, it should be mechanical, driven by the speedo cable out of the back of the t-case, unless someone swapped in an early '92 cluster w/ electronic speedo/odo. Check the cable out of the back of the t-case and see if it is a rotating mechanical cable or if it is the VSS (electronic sender) with a wire running from it.
Old Aug 12, 2011 | 03:27 PM
JamesD's Avatar
Kind of impossible since that is a mechanical speedometer. The only thing I can think of is one of the gears on the odometer broke and the vibration of engine is causing the odometer to move. Try turning the truck off and bang on the top of the dash to see if it moves.
James
Old Aug 12, 2011 | 03:54 PM
socal85toyota's Avatar
Old Aug 12, 2011 | 06:01 PM
flashkl's Avatar
better start praying
Old Aug 12, 2011 | 06:35 PM
James
Might as well yell some expletives as well. Works for me when I can't or don't know how to fix something and it usually fixes itself by the time I am done.
Old Aug 12, 2011 | 07:04 PM
Tofer's Avatar
Sponsor
*subscribes as well...*
Old Aug 12, 2011 | 07:15 PM
BMcEL's Avatar
Guaranteed to work 60% of the time, every time!
Old Aug 20, 2011 | 05:43 AM
Jasper 83's Avatar
Updates? I think everybody wants to know the answer to this one
Yont283
Sep 23, 2022 08:06 PM
ibayne
Jun 26, 2015 06:30 AM
WI Girl
Jun 25, 2015 03:45 AM
dirtrider0129
10
Jun 24, 2015 12:24 PM
saphirekosmos
Jun 22, 2015 10:26 AM
