PDA
View Full Version : 84-85 Trucks & 4Runners
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 [22] 23 24 25 26 27 28 29 30 31
  1. taking off the cab of '84 to weld frame
  2. Steering link upgrade for lifted pickup
  3. new pick up
  4. New to Me 85 pickup
  5. steering cocked
  6. Gears & Non 4x4
  7. tough starts in the mornings
  8. tacoma bed
  9. upgraded headlights for an 85
  10. Have to pump gas to get the motor to turn over
  11. Front locker issue
  12. speedo cable possible making noise
  13. what tire size are you runnin?
  14. alterations on my body
  15. Carb savvy?
  16. '85 4Runner Cleanup...
  17. Half Doors / Fiberglass Top
  18. heater problems
  19. 22rte wont start
  20. Hard Start
  21. 94 4 runner wont start
  22. What to look for once the head is removed.
  23. lifting my 85, what do i need to look out for
  24. Rear brake cylinder replacement Q
  25. 85 4cyl carb xtra cab long bed 4x4 opinions?
  26. What do u think?
  27. 84 4runner good starter vehicle or not?????
  28. Heater set up
  29. windshield wipers and fluid problem?
  30. Questions regarding a 1.5in shackle lift on my 84 4wd p/u
  31. No power to fuel pump with test jumper jumped
  32. Cold Start Injector issues with hotwired start! ahahahhahahhhhhhaaaaaaaa
  33. stalls while warm
  34. How to find TDC on the compression stroke.
  35. Rear brake replacement?
  36. Antenna Replacement..?
  37. 22 rec smog
  38. 22RE Intake
  39. show truck..............
  40. swampers?
  41. Question about replacing front main seal
  42. Stereo install, 12v acc, 12v always on, ground?
  43. tereflex
  44. Transmission Code 42
  45. Ac or heater blower?
  46. Black Smoke
  47. Hey you 85 guys!
  48. 22re Bottom End Knock.. help
  49. Temp gauge and oil pressure gauge problems
  50. 84' 22R needs 5 speed tranny
  51. heater core flush?
  52. while dash completely apart what to do?
  53. I may need a new motor. Aaarghhh!
  54. which header is better?..4 into 1 or tri y
  55. 85 22re RPM's wont come down between up shifts
  56. Timing chain guides broken - no noise from chain?
  57. Cleaning Switches
  58. 85 Grill Tabs
  59. Extra play in steering wheel?
  60. What's it worth?
  61. Rear Facing Seat? and 1 other question.
  62. Sea Foam... do you want the truth?
  63. Oil leak! Help please!...
  64. running bad
  65. UPDATE! con-ferr cab rack, 4wd pics, and MORE!
  66. Compression Test - High tension wire?
  67. 2 questions; center caps and SEAFOAM
  68. Dash Installation Help, temp controls ????
  69. bob job! sweet truck
  70. 87 Runner Back Seat Headrests
  71. Blinkers left blinks normal right is fast
  72. Rod Through Block
  73. 22R cam: install without doing HG?
  74. Sleeve for 22re crankshaft pulley
  75. Grey Carpet in good Shape
  76. How much would it cost?
  77. 85 Auto Windows
  78. 85 4Runner Seat belts
  79. 85 4Runner back window
  80. 22R valve adjustment
  81. Dynomax Super Turbo Muffler Part# 22RE
  82. interchangeable interior years
  83. New 85 4Runner 22RE auto
  84. 22re Crankshaft bolt replacement
  85. New here, please help - basic question about my 22r
  86. Timing Chain Tensioners
  87. Front TT break-in?
  88. Tach?
  89. Swaping a 22r out for a 22re
  90. Hooking Up Parking Brake On Disk Brake Swap
  91. New project runner build
  92. 1985 pick lift
  93. Need rear window help PLEASE
  94. Rear shackle question
  95. Buddys 2wd
  96. My truck builds...
  97. 84 pickup flywheel problems...
  98. low power?
  99. Rear locker questions
  100. My First Yota
  101. tachometer install
  102. New here; Hi... and HELP - thanksgiving/xmas presents on the way. BUILD
  103. 1986 22r ignition/alarm starting problem
  104. HELP! Really bad bogging down/stalling
  105. blinkers dont work
  106. Clean 85 Toy Truck on Autotrader
  107. CRACK heads stole my wheels ..
  108. 22re exhaust 1985 4Runner
  109. 85 wont wont rev up
  110. Whats safe
  111. Carb? Fuel Pump? AAP? Rebuild?
  112. air cleaner->carb gasket?
  113. '84 pickup 22r gasoline engine to "L" diesel
  114. 85 4runner idles good dies when accelerated help?
  115. Metric Bolt Question
  116. Marlin crawler parts in canada
  117. tire size???
  118. 1985 standerd pickup Subs
  119. Santa Made an Early Visit
  120. What am I missing?
  121. Where can I get starter contacts?
  122. volvo b230 oil filter on a 22re
  123. inner axle seals
  124. Project "Head on" begins..... 56k grab some coffee
  125. 1985 front axle seals.
  126. Got a free transmission WHAT IS IT
  127. Propane Conversion: Tank Locations
  128. windshield wiper...
  129. 22RE issue
  130. Connection on rear axle??
  131. 84 4Runner pinstriping.
  132. Rear axle
  133. TC replacement Q's
  134. Need some input on a 85 4Runner
  135. 84 California Emissions Weber Conversion
  136. Out with the tacoma, in with the first gen!
  137. Running horrible under load
  138. Grinding noise during slow right turns
  139. Sliders
  140. 22r woes
  141. grinding in front end
  142. Findings in my 22r leaving me baffled
  143. I need heat...
  144. Fuel Pressure VSV
  145. Any Help With My RC Lift??? Need Better Instructions :/
  146. Bought something cool today...
  147. Rear Electric Window Keyhole Jammed
  148. HELP, timing chain has developed slack on driver side
  149. Which way to go...?
  150. carb issues
  151. Purging the radiator
  152. Ebay Find in Oregon
  153. coolant in my intake
  154. 85 4runner wont rev past 4500 rpm
  155. My First 4Runner!
  156. whats the easiest engine swap
  157. tranny interchangeability
  158. Help Plz Strange Problem
  159. Picked up a little somethin today
  160. Aux Lights mounted by Windshield
  161. 84 4runner Quarter Panel
  162. Seat Swap
  163. 84 4runner, horrible mileage
  164. Need Carb Help...float bowl draining after the engine shut off??
  165. Sluggish Tach Needle
  166. Anyone put a removable tailgate on their 4Runner
  167. *Sigh* Help please :(
  168. City Motor Supply Engines
  169. Diff breather caps
  170. Head Gasket Tips?
  171. Probably dumb, but I just got a great deal on some 40s, what will I break?
  172. click and no bang
  173. Any "How to's" on removing/installing a dashboard
  174. Ebay Laugh of the week...
  175. Ok, something is wrong please help
  176. Front spring hangers
  177. Leaf Spring Options
  178. 84 4runner Exhaust?
  179. lower timing chain guide sheared...bad?
  180. Stock 4runner height.
  181. Thoughts on what it's worth?
  182. Problems with Truck
  183. Craigslist find NW WA
  184. TG X-member with Marlin dual adapter, will it fit?
  185. Latest scheme...
  186. Craigslist Finding
  187. Header?
  188. New After Market Tailgate 84 - 89 Help finding one!
  189. Soft top repair
  190. Just picked up a new toy today.
  191. 80 20r head on 86 22r block
  192. good deal?
  193. 22r teardown / rebuild / clutch replacement
  194. 85 4runner Low ridin on 37's
  195. Jumped into a head gasket job.
  196. Uh, what is it and where does it go?
  197. New member '84 pickup
  198. what model is this??? yota gurus see inside
  199. anyone in the poway area get new BFG A/Ts at Express Tire in poway today, 10/17?
  200. Help with dual case and w-56 combo
  201. Owner of Power Tank
  202. burning coolant 22r
  203. 86 4ruuner. Steering Pump Leaking
  204. 1st Gen 4Runners...Interchangeable Parts?
  205. Free reign on a 1987 4runner
  206. My 84
  207. Potentially My New Rig...Anyone With Input??
  208. Brake lights not working, driving me insane
  209. A little mod.. pics
  210. need help
  211. Ideas of what happened to my 22re
  212. Lead paint question
  213. not a stocker with a locker anymore!!!
  214. How much weight can the gutters safely take?
  215. 22r rough warm idle, sluggish acceleration, back firing
  216. 84 waggys really stiff
  217. HELP!!! asap
  218. 1985 yota pickup 22re
  219. Transfer Case Parking Brake?
  220. Getting Runner Ready for a Big Trip
  221. steering link
  222. leaf springs
  223. still almost overheating
  224. 5 series gears and 33's
  225. idle ?'s
  226. seatbelt dome light headlight warning buzzer
  227. 22-RE head
  228. Yota crawls over a large pile of wood (effortlessly!)
  229. this sucks.
  230. New 600 dollar 85 yota.
  231. New coils or spacers?
  232. Rim Question ??????????
  233. W-56 with matching T. Case from an 89 into an 84?
  234. Rear wiper/washer wiring
  235. 84 & 85 owners
  236. 85 PU Transmission grinding
  237. Frame rust on first gens
  238. FSM - nearly all years (Factory Service Manual)
  239. strange behavior and a pissed off owner
  240. Fuse Box / Relay question ... rear window.
  241. Removing 3.0 heads
  242. sr5 cluster swap questions
  243. '85 22re acceleration issues
  244. Cluster backlights not working anymore.
  245. Missing timing plate!
  246. Roof mount light bar
  247. Wanted Gear Driven T-case
  248. Tranny speedo gear replacement type?
  249. shackle Q...
  250. custom rear bumper
