What to look for once the head is removed.
Old Dec 12, 2008 | 02:57 PM
StLouisKingsnake's Avatar
Hello all! I just pulled the head from my 85 22r. What should I look for when inspecting for problems on the head and block? I am taking the head to a machine shop asap to have it looked over but I want to clean it up and inspect it myself first.
Thanks
Ben
Old Dec 12, 2008 | 02:59 PM
jsn_stockard's Avatar
What was the reason for pulling the head
Old Dec 12, 2008 | 04:13 PM
I pulled the head because a bunch of coolant steam was shooting out of the exhaust and it started to heat up. When I pulled the head off the #2 and #3 cylinders had coolant on top of the pistons. Someone had already done a new HG at some point, but who knows when, and if they fixed anything but the gasket. I don't like to leave anything to chance so I am doing the whole top end and the rear main seal(it is also leaking). This is my first job of this magnitude and I am doing it alone so I am very apprehensive and like to ask for the advice of the experienced yota sage's. I am also going to do a timing chain replacement so I can see what is going on in there.
Any and all advice is totally appreciated.
Ben
Old Dec 12, 2008 | 07:51 PM
I got the head cleaned up and noticed the #3 and #4 valves are very dirty compared to the 1 and 2. I also noticed on the #3 cylinder head area there is a little chunk of metal missing on the edge in between the piston top outline and a little channel. Any ideas? Is the head shot? I have a picture but I don't know how to post it up.
Old Dec 12, 2008 | 07:53 PM
I guess I figured out how to post the pic. If you look at the top right side by the channel you can see what I am talking about.
wwjr
Sep 7, 2015 09:27 AM
o2raybid
Sep 4, 2015 12:45 PM
Gargoyle_Runner
Aug 28, 2015 01:36 AM
87blyota
Aug 23, 2015 03:57 AM
themightykhoner
Aug 11, 2015 07:37 PM
