tire size???
Old Nov 16, 2008 | 08:23 AM
yota lover's Avatar
tire size???
Will a 32" tire rub or be to big to move for stock gears?
Old Nov 16, 2008 | 08:48 AM
bktaco's Avatar
You might rub a little at full stop, my 31" Revos (probably a relatively tall 31) rubbed a little in the back of the front wheel well when I had sagging stock springs. if your stock gears are 4:10, you will probably be OK to drive, but you will loose about 1 gear, ie, 5 is worthless, 4 become 5, 3 becomes 4 etc. you will not set any new land speed records.
Old Nov 16, 2008 | 09:45 AM
frankentoyota's Avatar
oh good because i plan on buying 32 inch tires with 4.10 gears and my fitfh gear doesnt work.. ahaha
Old Nov 16, 2008 | 05:09 PM
bigarms23's Avatar
put them on and if they rub cut fenders with sawsall
Old Nov 16, 2008 | 05:11 PM
yoder519's Avatar
theres a guy on here cant remember his name but he has a 1st gen yota its green with stock gears settin on i think 38s. so itll pull em
Old Nov 16, 2008 | 05:17 PM
4banginRunner's Avatar
Maybe with a V8!
My 20R can barely turn 32s with 4.38s, I had 35s on it and it was scary slow (and I'm used to driving Toyota's), I can't imagine 38s with the stock setup.
Old Nov 16, 2008 | 05:27 PM
84RNR's Avatar
I've got 35s with stock 4:10 and it's no slug. I've been wheeling like this for over a year. I'm not even that worried about re-gearing yet. I'll get a e-locker 1st. The manual trans does help. I disagree that with only 32s you'll loose 5th gear. With my 35s I don't use 5th but with 32s you definitely would. (But you didn't mention what kind of truck/motor setup you have so I'm just speaking for a 22r.)
Old Nov 16, 2008 | 05:33 PM
yoder519's Avatar
teh guy i was talkin about name is ryantowry 81. but i jsut read a thread wher he said he blew it up
Old Nov 16, 2008 | 05:48 PM
84RNR's Avatar
Blew what up? The birfs, motor, diffs?
Old Nov 16, 2008 | 05:51 PM
yoder519's Avatar
oh sorry the motor
Old Nov 16, 2008 | 05:59 PM
mosser84toyota's Avatar
yea it will pull them fine. i ran 32's befor and it was fine but now im on 37s with stock gears till i can get money for them.
Old Nov 16, 2008 | 07:33 PM
yota lover's Avatar
Does this mean lower top speed or lesspower i dont really care about the top speed but the power is a worry. Will the over bore and cam help with this?
Old Nov 17, 2008 | 10:12 AM
yoder519's Avatar
itll have less power , but hte same top speed goin down hill lol
Old Nov 18, 2008 | 07:35 PM
yota lover's Avatar
I put the 32" all terrains on today, it tore it up on the dirt, it did not even rub!
Old Nov 18, 2008 | 07:55 PM
abecedarian's Avatar
need to update your signature.
djpg2000
Nov 11, 2020 04:56 AM
jgallo1
Oct 26, 2015 06:39 PM
Gravel Maker
RuffStuff
Aug 6, 2015 04:27 PM
Luvmeye22re
Aug 4, 2015 03:53 PM
coffey50
Jul 28, 2015 10:55 AM
