Running horrible under load
Old Nov 10, 2008 | 02:22 PM
Emt-Iyotaguy's Avatar
Ok once again i am back to wrenching on the 87 pickup with the rebuilt 22ret anyway back story. After my initial rebuild it wouldnt start unless using starting fluid anyway after taking to the shop a ground wire had been left off that grounds the ECU anyway after paying this guy to find the grounds and set the timing i got it home and the next day went out for a drive. Now for the problem as soon as i get under a load it begins to act like its hitting fuel cut it just tries to shut down with a very hard jerking motion and kinda acts like a miss (hard to describe) also can hear it poping through the exhaust any way i had a knock sensor code so i replaced that also had a code 14 which is a over boost code that they tell me is a fuel cut code anyway, also replaced the tps and tried to reset the timing when I hook up the jumper there is no change in the timing which is supposed to mean you have a bad TPS any way any help would be greatly appreciated
Last edited by Emt-Iyotaguy; Nov 10, 2008 at 02:23 PM. Reason: oh and it refuses to go above 3k RPMs it dies if i try
Old Nov 10, 2008 | 02:30 PM
904_runner's Avatar
not sure if it is related or not, but my truck had the symptoms where underload, like pulling hills, etc..
my truck would fall on its face with absolutely no power at all. It turns out i had a clogged catalytic converter. It may be worth a shot for you to unbolt the front flange so there is a massive exhaust leak. drive it around and see if that was the problem.
Hopefully that helps a little.
Old Nov 10, 2008 | 06:04 PM
Thanks for the reply but this truck doesn't have a cat (shhh dont tell the emmisions guy)
Old Nov 10, 2008 | 06:10 PM
stagger_lee's Avatar
Do you have a manual boost controller? How much boost are you running? Fuel pump?
Old Nov 11, 2008 | 06:20 AM
no everything is stock and the fuel pump tests fine
smthwsn357
May 1, 2024 07:28 AM
the1998sr5
Jul 16, 2015 06:20 AM
skoti89
Jul 8, 2015 12:05 AM
Nickdigg
Jul 7, 2015 06:04 AM
