Gears & Non 4x4
Old Dec 15, 2008 | 06:31 AM
ttlycnfuzd's Avatar
Gears & Non 4x4
Does anyone know the best place to buy a set of gears for my 85 pickup? It is a 2WD running 31's.... I know the truck is capable of a lot more power, but I love the look with the lift & tires. I am located in SoCal if that helps....
TIA
Old Dec 16, 2008 | 01:58 PM
TrikeKid's Avatar
As long as it's a 7.5" rear end you should be able to run gears for a 4WD IFS front. Might even be able to run the whole third member out of one, that'd give you 4.10's or 4.88's depending on what truck it came from.
Old Dec 16, 2008 | 02:03 PM
stagger_lee's Avatar
http://www.precisiongear.com/home.htm
These guys are cool.
http://www.pomonagear.com/
Old Dec 16, 2008 | 02:15 PM
ttlycnfuzd's Avatar
-trike-Thanks for the response.
Another question.... the fact that mine is a 5 lug setup, and the 4wd is 6 lug - does that make any difference? I had grabbed a ring & pinion out of a 4wd rear, and the bolts didn't line up... so try the front?
-stagger - I will try those recommendations....
Old Dec 16, 2008 | 03:11 PM
abecedarian's Avatar
on 86-95 4wd, the rear is 8" and the IFS front is 7.5"
that's why trike suggested getting the IFS "front" since your 2wd is 7.5"
Old Dec 16, 2008 | 06:43 PM
scuba's Avatar
INLAND EMPIRE FTW !!!!
Welcome to YotaTech...
Old Dec 16, 2008 | 08:01 PM
ttlycnfuzd's Avatar
Allright... think I have all my info in order... guess I gave been looking at the wrong parts.
I will try the junk yards and see what I can come up with....
have a beer or 2 on me
Old Dec 16, 2008 | 08:36 PM
^^ Doin it ^^
Only if you aren't doin it yourself. Labor on rear ends can get expensive. Pretty easy to bolt in a 3rd if you find one.
The Ecology on Imperial Hwy in Norwalk, usually has a decent selection of yotes, 2wd and 4wd.
Just swapping 3rds, lugs wont change because you will use the same outers/axles. Like Abe and Trike said. 7.5 4wd IFS 3rd into 2wd rear. Done.
Old Dec 16, 2008 | 08:56 PM
Tofer's Avatar
Sponsor
where do you plan on putting this
in the Rear axle?!!
yes the front ifs is 7.5 and the rear 2wd is 7.5.... but you cannot put a IFS front 3rd in the rear of a 2wd truck...... you will have to reset the gears.
another suggestion is watch craigslist for a narrow 4wd rear end.. you'll have to get new tires for the rear (and will have 5lug front and 6 lug rear) but it will give you SOA and the 8" gears
Old Dec 16, 2008 | 09:09 PM
scuba's Avatar
I thought the front was reverse cut also...?
Old Dec 16, 2008 | 09:13 PM
ttlycnfuzd's Avatar
Ah... yeah... gears only for me... LOL
as for the two different lug setups - don't think I want to go there. My luck would be that whichever rim I have as a spare, the opposite would go flat on me.
Short of pulling the whole thing apart and counting gears, is there any way to visibaly/externally tell what the gear setup is? don't want to waste half my day at the junk yard tearin into 20 different trucks/4runners..
Old Dec 16, 2008 | 09:39 PM
scuba's Avatar
Theres a gear chart somewhere...And the axle code will be on the drivers side door jamb...
Old Dec 16, 2008 | 10:11 PM
ttlycnfuzd's Avatar
ok... did a quick google... found some good info on the coding for the gears.... gotta make time to go to the junk yard....
Old Dec 17, 2008 | 07:36 AM
Thought so too.
Junkyard off of the 91 and Glassel in Anaheim, between 57 and 55 has some yotes too.
Old Dec 19, 2008 | 08:11 AM
I just found a new place (new to me) in Santa Ana that claims the largest Toyota and Nissan mini truck wrecking yard in So CAl. PM me if you need the info ttlycnfuzed.
I am going to pick up a 22r block from them this weekend for $120, re-buildable shortblock w/crank rods and pistons. I'll let you know what it looks like.
Old Dec 19, 2008 | 08:24 AM
ttlycnfuzd's Avatar
pm sent
Old Dec 19, 2008 | 09:06 AM
back at ya.
XtraCab
Apr 12, 2020 05:25 AM
mskalmus
May 28, 2017 07:51 AM
Tykiller1994
Aug 10, 2015 07:49 PM
Seattle_Sign_Guy
Jul 12, 2015 12:38 PM
MTLroadierunner
Jul 6, 2015 12:17 PM
