Blinkers left blinks normal right is fast
Old Nov 27, 2008 | 10:00 PM
oleboy's Avatar
Can anyone give me any ideas about my blinkers the left blinks normal and the right blinks like a rabbitt in heat very fast. Any ideas? Thank you.
Old Nov 27, 2008 | 10:07 PM
pennywize's Avatar
are all the actual signals outside blinking? usually when one goes fast it means somewhere a lamp is burned out. check to see if the signals outside are actually flashing.
Old Nov 27, 2008 | 10:13 PM
swapped89's Avatar
ya samething pennywise said. a fast blinker usually means one of the blinkers on that side is blown out.
Old Nov 27, 2008 | 10:29 PM
oleboy's Avatar
Ok so the front and rear on all 4 corners are lighting up. Could it be the relay in the fuse panel inside the cab??
Old Nov 27, 2008 | 10:36 PM
rowdy235's Avatar
if they're all working why worry about it? Don't mean to sound like a jerk, but don't fix whats not broken. Do keep an eye on them though, sometimes blinking fast is an indication of a bad ground that they only blink sometimes (My RV did that)
Old Nov 27, 2008 | 10:42 PM
olharleyman's Avatar
check your connections to the blinker lights mine did that and I found the conneter was half plugged in and making contact off and on.
Old Nov 28, 2008 | 12:55 PM
Johannes's Avatar
All of my blinkers do that, I haven't worried about it too much, all the bulbs are working, it's just that fast "something isn't right" flash.
Old Nov 28, 2008 | 01:30 PM
scuba's Avatar
Original poster...Sounds like your blinker fluid might be low
Old Nov 28, 2008 | 02:04 PM
littlecommando's Avatar
That must be it, the blinker fluid dipstick is sitting in the drivers seat if you want to check it
Old Nov 28, 2008 | 02:08 PM
oldgold3vze's Avatar
Also sometimes they blink fast to let you know that one is about to burn out. I'd just wait until something doesn't work, but yeah, I can see how that would be annoying.
Old Nov 28, 2008 | 02:18 PM
scuba's Avatar
Hey at least they dont blink UBER slow after a good weeks rain...Still cant figure that out
ghostmoney
Jan 28, 2018 11:42 AM
Dennisx2
Aug 10, 2015 06:48 AM
NolaToyota
Aug 7, 2015 10:10 PM
Dennisx2
Aug 4, 2015 01:26 PM
ripp96
Jul 25, 2015 02:32 PM
