Sluggish Tach Needle
Old Oct 31, 2008 | 06:02 PM
mountaineertom's Avatar
Has anyone had their tach be slow/sluggish on cold mornings? Since it's gotten colder here, I've noticed the tach needle either doesn't move at all or moves very slow. After 5 minutes or so, it seems to work fine. The speedo needle works fine right from start-up.
Old Oct 31, 2008 | 09:17 PM
khoopes's Avatar
I bought a used SR5 cluster that I assume was sitting for a while and the tach needle is a little iffy. The movement is probably sticky or damaged and overdampening, yours sounds like sticky. Analog meter movements are delicate but you might be able to lubricate it with a drop of very light oil??
Old Nov 27, 2008 | 05:22 PM
matts65ss's Avatar
i did the sr5 cluster swap and my tach does the same things if its a nice warm day out it works fine. if its a cold morning then the tach is very sluggish if it evens moves at all. then after 5 or 10 min it starts to work fine
Old Dec 22, 2008 | 05:42 AM
I couple weeks ago, I tried putting a little bit of lube on there. It helped a little, but it still doesn't move at start up on relly cold days.
Thanks for the tip though.
Old Dec 22, 2008 | 09:13 AM
bktaco's Avatar
need to lube the cabled to the tach. remove cable to tach, dribble some light oil or wd-40 on the cable end, drive, repeat, a few times a day for a few days to work the lube in. If you want to go nuts, do the same thing on the xfer case side. this works.
Old Dec 22, 2008 | 09:26 AM
ozziesironmanoffroad's Avatar
your talking about the speedo cable, BKTACO. the tach is ALL ELECTRIC. the cable ur talking about is broken on my truck and my tach works. so no the tach does not run off the speedo cable.
Old Dec 22, 2008 | 03:05 PM
bktaco's Avatar
ah, you are correct sir! thanks for that.
shisha1999
Mar 3, 2016 07:09 PM
Jdgarrison
Oct 1, 2015 05:22 PM
Jdgarrison
Oct 1, 2015 02:11 PM
Shagool22
Sep 28, 2015 07:53 PM
jacked_72
Sep 14, 2015 03:31 PM
