inner axle seals
Old Nov 14, 2008 | 04:44 PM
84yota4x4's Avatar
inner axle seals
well my seals are shot and i was wondering how hard they were to replace? any advice is helpful, thanks
Old Nov 14, 2008 | 05:04 PM
slacker's Avatar
heres some "poop" hope it helps ...
http://toyotatrekker.proboards107.co...play&thread=63
Old Nov 14, 2008 | 06:03 PM
bktaco's Avatar
i average a day for disassembly, a day for parts cleaning, and a day for reassembly. but i work very slow. 4x4wire.com for step-by-step
Old Nov 14, 2008 | 06:06 PM
INFINITY's Avatar
fronts are kind of a pain BUT if they need to be done then they must be.
i would recommend marlin crawlers. they worked out great and you cant beat the price.
Old Nov 14, 2008 | 09:05 PM
mdelros's Avatar
I'll be watching this tread cause the seal on my 83 pick-up - front left hub is also leaking gear oil.
Old Nov 14, 2008 | 11:27 PM
86tuning's Avatar
Yup. These are modified seals and are much easier to install. Highly recommended.
Old Nov 15, 2008 | 05:51 AM
waskillywabbit's Avatar
Axle seals are easy to install...getting all the crap off to get to them just takes time.
Old Nov 15, 2008 | 06:55 AM
netwt12's Avatar
use the marlin crawler seals. unless you want to rebuild everything else remove the hub and then remove the 8 bolts for the felt protectors on the back of the knuckle. remove steering arm. take the knuckle and spindle off as an assembly. pull out inner axle and birf. remove old seal and tap in marlin seal. it should take less than an hour per side.
Old Nov 15, 2008 | 06:57 AM
netwt12's Avatar
if you want to tear it all apart here is a good write-up
http://www.birfield.com/~morgan/tech/axle/
Old Nov 15, 2008 | 01:09 PM
84yota4x4's Avatar
thanks i think i may be able to pull it off...lets hope so anyways.
Old Nov 15, 2008 | 02:51 PM
NorCrawler's Avatar
thats a crap ton of grease.
polo451
13
Nov 20, 2016 07:49 PM
Jcrawl94
10
Oct 24, 2015 04:34 PM
jerusry
Oct 19, 2015 05:28 PM
yoder519
Aug 17, 2015 07:12 AM
yourrealdad
Jul 21, 2015 11:13 AM
