Which way to go...?
Old Nov 6, 2008 | 04:09 PM
algranger's Avatar
Which way to go...?
Alright so i just bought a new truck with a rod knock'n 22r. Pulled the oil pan today and found the #4 rod has lots of slack which i expected. I also found a heap of parts sitting in the oil pan.. obviously a broken timing chain guide, it has some pretty major grooves worn into it too. So can just replace the guide? Or should i do chain and gears too? What would you guys reccomend? Thanks!
Edit: Oh yeah theres a little spring about 1.5" long and 3/8" in diameter is that part of the timing chain guide?
Old Nov 6, 2008 | 04:14 PM
scuba's Avatar
Sell it to me for 100 bucks !!!!
Old Nov 6, 2008 | 05:49 PM
algranger's Avatar
Give it to ya for 3k
Bump. I need more thread!
Old Nov 6, 2008 | 05:59 PM
BigBluePile's Avatar
How many miles and sounds like a rebuild? I wouldn't just change guides, I'd do the whole timing chain system. As far as the spring...is it springy or really compact and thick?
Old Nov 6, 2008 | 06:26 PM
algranger's Avatar
The problem is, i'm tight on time and money i work and go to school but i may just have to deal with a little extra down time.
Heres a pic of the spring
Now heres the other thing.. i have an extra 22r that was given to me non running, i donno whats wrong with it but if the bottom end is good i may use it with the new truck's top end on it cause the new one runs PERFECTLY. What do you guys think about that?
Old Nov 6, 2008 | 06:35 PM
Are you doing calculas?
Anyways. Yeah, that would definately work. Just long as the other bottom end is good. I know I've seen that spring. grrrrrrrrrrrrr.
Still, sounds like the same amount of work. Still have to pull the motor, still have to put a head gasket(well, all seals really) on and the new timing chain stuff. Plus, who knows if the water pump or oil pump is worth a poop...but hey, details baby, details!!!!!
Old Nov 6, 2008 | 06:37 PM
just a 22re's Avatar
i would say rebuild her and take your time if shes not a dd then why not do what you can here and there untill you get her done even if it takes you a year to do its all good take your time and do it right replace anyhting you dont wanna have back in there
and yes i would replace the chain guides and gears to
Old Nov 6, 2008 | 06:39 PM
abecedarian's Avatar
... looks like the oil pressure relief spring
Old Nov 6, 2008 | 06:41 PM
scuba's Avatar
Actually, thats the spring I threw at you...
did it hurt....GOOD !!
Old Nov 6, 2008 | 06:45 PM
Originally Posted by just a 22re
i would say rebuild her and take your time ..........
Yup, when I spun the bearing on the #1 rod I made sure it was done right and found a machine shop that rebuilds 22r motors. They did a great job and it was well worth the wait. It was also cheaper, 'cause I did all the heavy work myself. Of course it was my DD and I had to rent, but that just what I had to do.
You can check out my pics (https://www.yotatech.com/gallery/sho...ser=20182&sl=b) and see how purty it was when it came back.
Old Nov 6, 2008 | 06:46 PM
Yeah, that's what I was thinking but how the heck can it get to the oil pan??!?
Old Nov 6, 2008 | 06:51 PM
algranger's Avatar
i donno this thing might have more issues than i thought
Old Nov 6, 2008 | 06:56 PM
algranger's Avatar
i'm thinkin maybe ill just use the extra bottom end
Old Nov 6, 2008 | 07:08 PM
Like I said, it's all the same work, unless the other one craps out then it's twice the work!!!
Atleast have the old bottom end looked over.
Old Nov 6, 2008 | 07:10 PM
algranger's Avatar
yeah good point.. i just cant get hasty which is what i'm doin lol
Old Nov 6, 2008 | 07:24 PM
Remember:
"THE BITTERNESS OF HASTINESS
REMAINS LONG AFTER THE
SWEETNESS OF MAKING IT WORK IS FORGOTTEN"
I think I totally made that up...
Old Nov 6, 2008 | 07:58 PM
algranger's Avatar
lol yeah it was awkward.. but a good attempt
The bitterness of low quality remains long ofter the sweetness of low cost is forgotten.. somethin like that.
im gonna start pullin the head right now, im goin in timing chain, gears, guides, connector rod bearings are on the way!
Old Nov 6, 2008 | 08:08 PM
Oooohhh Snap!
Take pics!!
Old Nov 6, 2008 | 08:57 PM
stagger_lee's Avatar
What about engnbldr? Cant you get a T chain kit, and rods for a bit over $100? Everything for under $200? Trust me I understand budget brother. DO it yourself? What do you think someone will charge to look over a bottom end?
NIce avatar by the way. Made me pull out some old cds.
Old Nov 6, 2008 | 09:50 PM
algranger's Avatar
Hah thanks thats my favorite album of theirs.. they're one of my favorites of all time. I donno how much for a bottom end lookover.. i'm doing the rod bearings and probly a crankshaft seal too. NAPA wants a little over 200 for the head set, and the timing set. with that i get all the gaskets needed for the head installation, and the timing chain, gears, guides and some other thing i donno what it is lol. but i donno napa is cheap ill look into engnbldr
Team420
Dec 30, 2015 01:31 PM
Falcon78
Engine Swaps
Jul 1, 2015 05:01 PM
Balzonya
May 10, 2011 06:51 PM
kpooch75
11
Jul 6, 2005 02:42 PM
