idle ?'s
Old Oct 9, 2008 | 06:18 PM
t_boneshacone's Avatar
idle ?'s
ok so my truck is idling high and i think i know why, the idle control screw has broken, but it only idles high after i push the gas, can anyone tell me why, also its a efi
Old Oct 9, 2008 | 06:32 PM
locked stock 84's Avatar
How about pics of broken control screw? Is it broken externally? how long does it idle high?
Old Oct 9, 2008 | 06:37 PM
yea the thing at the top is like chipped, so most of the hex head is still there but then like a 1/5 of it is missing, and it idles high after you push the gas and the more you push it and let off the higher it idles
Old Oct 9, 2008 | 08:09 PM
Green93's Avatar
Not sure if you checked, but is your pedal sticking down at all? When it is idling high just reach down and pull the pedal up. Could be as easy as a worn spring. I always start with the easiest stuff first.
Jason
Old Oct 10, 2008 | 04:43 AM
its not really the pedal i dont think, because i tried pulling it back up
Old Oct 10, 2008 | 03:48 PM
abecedarian's Avatar
could be gunk on the throttle shaft holding it open
could be a weak return spring
could be the cable sticking
...and what do you mean hex screw on the adjuster? idle speed is adjusted by a screw on the top of the throttle body that has no affect on the throttle shaft or plate- it is a 'needle' valve that lets air bypass the throttle without physically moving the throttle and it is adjusted with a flat/standard screwdriver.
Are you referring to the throttle stop screw or the dashpot on the side of the throttle? If you're using either one of those, it's no wonder your idle speed is drifting since either of those will keep the throttle from fully closing and will cause the throttle position sensor to not send the IDL signal to the ECU, thus complicating the issues with the idle speed.
Old Oct 10, 2008 | 04:53 PM
well that explains alot, i think i will adjust the one abec said tomo, my papaw started adjusting the other so i just assumed but we all know what assuming does
Old Oct 10, 2008 | 05:01 PM
4Crawler's Avatar
Also check the dash pot under the throttle linkage. If it is dirty or plugged it'll hold the throttle open:
http://www.4crawler.com/4x4/CheapTri....shtml#Dashpot
Blamalam
Mar 12, 2022 07:34 AM
Marsheen
Feb 17, 2016 12:29 PM
GrimWolf
Aug 28, 2015 03:36 AM
noosh
Aug 21, 2015 03:49 AM
Sarcazmo
Aug 15, 2015 08:22 PM
