85 4runner idles good dies when accelerated help?
Old Nov 16, 2008 | 02:16 PM
rfinn04's Avatar
I am thinking of buying this 85 4runner the truck seems solid starts right up runs smooth at idle but when you give it any throttle it starts to sputter and will die. any ideas is this common this is an efi 22rec
Old Nov 16, 2008 | 02:31 PM
toyota4x4907's Avatar
What I would do first is look into the intake past the throttle body/ butterfly valve, if there is a lot of black goo/residue, the engine could be gasping for air. The air filter may need to be changed/cleaned. The fuel filter may need to be replaced and/or the injectors could be dirty. Run some SeaFoam in the gas tank and the intake. after that, Im not sure. Someone who knows about like vacuum leaks, etc. might chime in...or, your best bet would be to search if you haven't already. Or search some more...
Old Nov 17, 2008 | 06:44 PM
myyota's Avatar
I would replace the fuel filter and see if that makes a diference, you can also check the throttle position sensor, and if none of that helps then it night be a bad fuel pump, also the timming could be off, has the timming chain ever been replaced ?.
sonic concepts
Aug 16, 2025 03:13 PM
Ladythump
Jul 4, 2015 03:35 PM
94hiluxZE
Jun 22, 2015 10:42 AM
Mutinebullfrog
Jun 18, 2015 01:36 PM
XtremeOff-Road
16
Jun 27, 2002 07:32 PM
