Carb savvy?
Old Dec 13, 2008 | 10:40 PM
algranger's Avatar
Carb savvy?
i searched. a lot.
when i fire up my 85 22r idles really rough like its missing and it dies half the time. about 1600+ rpm's it runs perfect but anything below that it just idles like crap? anyone had this problem? any suggestions would help thanks
Old Dec 13, 2008 | 11:02 PM
myyota's Avatar
Check the AAP and see if its leaking fuel into the vacuum line.
Old Dec 14, 2008 | 06:37 AM
pcmentor's Avatar
Valves too tight or too much air.
Old Dec 16, 2008 | 01:52 PM
TrikeKid's Avatar
Check for vacuum leaks, spray some carb cleaner around on the base of the carb and the vacuum lines/junctions. Check the choke isn't sticking.
Has it just been the last while that it's turned arctic here? Try some Heet in your gas, might just be the carb icing up.
Old Dec 16, 2008 | 08:53 PM
ttlycnfuzd's Avatar
mide does the same... but have you noticed that it seems to hesitate on takeoff - or if manual - having to pump once or twice before enageing the clutch? - accelerator pump diaphragm (among other things) was my main culprit. replacing the carb with a rebuilt unit.....
Old Dec 16, 2008 | 09:16 PM
algranger's Avatar
ill have a look through for leaks. i only got the truck running last thursday so i couldnt say if its the temp. i put the carb on when it was cold so maybe i vacuum line cracked. i took the carb off and soaked it in cleaner then rem-oil to and made sure everything moved real smooth it helped a little.
yeah it wouldnt suprise me stock carb 243,xxx mi. and yes it did hesitate a little like it was short on air or fuel. i have an diaphragm thats good i might throw it on there
im thinking it may be the choke ill check into it tomorrow thanks guys
Thamuel_
Domestic Swaps
Oct 3, 2015 11:15 AM
the_supernerd
Oct 1, 2015 09:20 PM
Rerun
3.4 Swaps
Oct 1, 2015 12:24 PM
Toys4parts
Sep 26, 2015 01:56 PM
taraf
Sep 25, 2015 02:57 PM
