Heater set up
Old Dec 11, 2008 | 06:57 PM
yodercrawler55's Avatar
Question Heater set up
I have a 85 toyota 4 runner with a very recently rebuilt engine and new radiator, when i turn my heat on there is heat but its not pushing enough out. What do i need to fix?Any ideas?
Old Dec 11, 2008 | 07:19 PM
myyota's Avatar
Sometimes the air duct between the blower and heater get full of leaves and crap and will restrict air flow, you will need to take it a part and clean it out.
Old Dec 11, 2008 | 07:24 PM
hmm sondsike that could be possible i thought i heard someone say there was a cable that was linked to a hinge on the firewall that somehow controlled the heat flow
Old Dec 11, 2008 | 08:37 PM
myyota's Avatar
The heater valve is located on the firewall, and its controled by a cable conected to the heater, if its not hooked up or working then you won`t get any heat, check that first to make sure it working.
Old Dec 11, 2008 | 09:13 PM
85toy's Avatar
kinda off topic but where do all the leaves and crap come from, where does the heater pull in air from?
Old Dec 12, 2008 | 05:46 AM
myyota's Avatar
The heater pulls air in from under the cowl, so any leaves and dirt that get in there can get sucked into the heater blower and then into the heater.
Corvoid
Jul 4, 2021 11:51 PM
the1998sr5
15
Jul 14, 2020 08:35 PM
viesail
Aug 17, 2015 08:39 PM
94 Newbie
Aug 6, 2015 10:33 AM
Bucksnuff
Jul 31, 2015 07:09 AM
