leaf springs
Old Oct 10, 2008 | 06:08 PM
algranger's Avatar
leaf springs
ok so heres the deal i have an 84 pickup as my dd and its in almost perfect shape, i really dont plan on wheelin this one that much as i will be purchasing a 1st gen as a dedicated play toy soon. my question, what do you guys think of rough contry springs for my dd, i just want it up off the ground a little bit but like i said probly wont wheel it a whole lot.. i know rough country is about as cheap as it gets but do you think there would really be a quality concern for this application?
much appreciated
Old Oct 10, 2008 | 06:48 PM
baseballchamp157's Avatar
ummm if your goin for a lift then ya itll be alright. I mean its not like your goin to put it threw anythang if its you DD. Plus the kit is easy. I put a 3in on my 85.
Old Oct 10, 2008 | 06:49 PM
4x4YOTA's Avatar
its not to bad for the price but I dont recommend the rear springs there way to stiff and ride like $#!! I have a friend that has it and he is very happy but I recommend pro comps 3" kit I have there 4" and loved it rode great and flexed awesome
Old Oct 10, 2008 | 07:41 PM
phildelfino's Avatar
I bought JC Whitney rear leafs for mine and they are rough country (I think) and are very bouncy.
Old Oct 11, 2008 | 07:47 AM
algranger's Avatar
hmm stiff huh? that doesnt sound too nice for driving 2+ hours a day. how do they handle weight? i remembered i need to carry heavy loads for work every now and again. i was thinking last night maybe putting a 3" add a leaf on there and buying some junkyard rears to go on the front what do you guys think of that?
edit: how much front lift does therears up front give ya?
Old Oct 11, 2008 | 02:26 PM
85toy's Avatar
depends on how ya do it the ruf as to how much lift you get. how are you planing on setting it up?
Old Oct 11, 2008 | 05:54 PM
lt1toy's Avatar
rough country sucks trust me spend a little more for something better i have bent 4 leafsprings so far my jeep has 4 inch lift now its 1 inch lift my tires now rub i am not jumping this jeep either i would not tell anybody to get rough country
Old Oct 13, 2008 | 09:57 AM
mickeykreg's Avatar
I just did the OME springs all around. The ride is real nice. Once I got into the job and discovered there was no way (within reason) to reuse the old shackles I went with the Downeys. 1" over stock in front, 1.5" over stock in back. I used Energy Susp. greasable bushings. Downey builds the front shackle plates correctly from the start (imo) without using the cheap ass looking spacers.
Heres the final ride height. The tires are 33's.
If I had it to do over again I think I'd shoot for less lift. I'd probably use the Downey shackles with some new stock height replacement springs from SixStates.
Here are the SixStates part numbers: Fronts#90-114/$132.31ea. Rears#90-119/$195.31ea.
http://www.sixstates.com/products/products.jsp
Old Oct 13, 2008 | 11:08 AM
4Crawler's Avatar
Spacers on the front shackles allow the side plates to clear the frame and allow for more shackle swing backwards. But that all depends on how much shackle angle you have. One thing to watch for on the Downey shackles is that the nuts tend to loosen and back off the inside of the shackle:
http://www.4crawler.com/4x4/ForSale/...l#Introduction
I add a pair of tabs to the outer shackle plate to keep the bolt from turning inside the shackle and working the nut loose:
Old Oct 13, 2008 | 11:39 AM
algranger's Avatar
thanks guys
that looks real nice , how much did you pay all around? gotta save my money for my play toy
Old Oct 13, 2008 | 04:57 PM
mickeykreg's Avatar
I spent about $460 on the 4 springs, shipped and another $125 for the shackles, fronts and rears, shipped.
BTW: I purchased my springs from 4x4 connection about three weeks ago. The guy told me the prices were going to go up this fall. Take it for what its worth.
hiluxinargentina
Sep 30, 2015 05:51 PM
JookUpVandetti
Sep 30, 2015 08:58 AM
Cycles
Sep 29, 2015 06:37 AM
oldblue
Sep 28, 2015 04:07 PM
83
Sep 27, 2015 04:13 PM
