Tranny speedo gear replacement type?
Old Oct 2, 2008 | 09:56 AM
HemiDave's Avatar
Hey Guys,
I have an 85 5 speed 4x4 pickup that stripped the speedometer gear and haven't had any luck finding a replacement. The dealer is a waste of time..they don't want to fool with it as they say there are a few types and don't want to order the wrong one.
What do I look for to find a replacement for the stock gear? Are there different colors or do I need to count teeth?
I didn't think it would be so difficult....
Thanks!!
Dave
Old Oct 9, 2008 | 05:55 AM
HemiDave's Avatar
No one?
Dave
Old Oct 10, 2008 | 02:05 AM
XtraSlow_XtraCab's Avatar
My dad tells me you used to be able to go to a transmission shop and tell them what kind of truck, gear ratios, and current-size tires. From there they could pick you out the right speedo gear.
So my friend Drew gets 33's on his 4:10 82 truck, goes to the tranny shop and talks speedo gears, and the guys says: "What the Hell are you talking about"?
...So much for experienced help. I hate shop owners that look down on shade tree mechanics. Its college classes for every ****ing job nowadays.
Old Oct 21, 2008 | 10:04 AM
HemiDave's Avatar
I'm just looking for a replacement at this point. Tried Downey and others with no luck. Is it the same as other models are unique to the 85 4x4? Any help appreciated!!
Dave
Old Oct 23, 2008 | 09:40 PM
anotherjeff's Avatar
A couple of questions, if you don't mind...
Which "speedometer gear" are you talking about? Underneath or Dash?
edit: OK, I looked closer: the OP said "Tranny" gear!
Have you removed the "stripped" one from your truck? (You could do a side-by-side if someone whips out a possible swap...)
Have you ID'ed your tranny/transfer? It might make a difference...
Could you complete your Profile? It helps in many ways. Regional stuff like dirt on local parts, for instance.
Good Luck
Old Oct 24, 2008 | 12:26 AM
Carbbed 22R should have a G52 or G54 transmission.
EFI 22R supposedly used the W56. Shouldn't matter wither way, I think they were all rated at the same gear ratios, just improved strenth.
And a 5 speed 22R(E) 4x4 should have a 4:10 rear gear ratio.
Kalihi,HI
Jul 9, 2015 04:29 PM
colinmil
Jul 6, 2015 04:03 PM
Jnkml
Jul 6, 2015 01:20 PM
MTLroadierunner
Jul 6, 2015 12:17 PM
wilbertd
Jul 6, 2015 07:39 AM
