High Pinion 3rdwont fit?
Old Jun 19, 2011 | 10:21 AM
85 FF / medic's Avatar
Hey guys..... I put a high pinion front 3rd in last month. It is a Marlin Crawler with a grizzly locker. Durring the origional install I snapped a couple studs. So I took it out today and replaced all the studs with an eliminator kit. Now I cant get the 3rd back in. It looks like I need to trim the slot for the ring gear, but it fit with no problems before. I am quitting before I take a chainsaw to this thing but could really use some help before I try again tomorrow. Thanks!
Old Jun 19, 2011 | 10:29 AM
waskillywabbit's Avatar
Sometimes the studs aren't just perfect and the holes in the diff aren't quite lined up. You shouldn't have to cut on the housing. Perhaps message the diff with a rubber mallet.
:wabbit2:
Old Jun 19, 2011 | 10:48 AM
4Crawler's Avatar
Usually you can jiggle the pinion flange back and forth a little to move the ring gear teeth into just the right alignment to slip into the two slots on the housing. But to make life easier, I hit those slots with the edge of a grinder wheel and open them up just a hair. Likewise, I hit all 10 flange bolt holes with a drill bit about 1/32" larger to make it easier to fit the diff over them. Hard enough wresting a bulky 60lb. hunk or steel into the axle without having to fight a tight fit on top of that.
Old Jun 19, 2011 | 11:41 AM
I like that solution. I wiggled every which way and beat it like it owed me money with my small mallet. Hopefully if a cool head don't change thongs in the morning, a little grinder treatment will. Thanks gents
Brian
Old Jun 19, 2011 | 06:03 PM
laskt9's Avatar
i just had the exact same problem. i bought a rock assault front axle with the eliminator kit and one of the holes didnt even line up. so i pulled one of the studs. pounded the hi pinion on with a mallet and put a bolt in the empty hole. it made me really mad that i spent 700 bucks and the holes didnt line up.
kazuya2416
Apr 5, 2024 02:17 AM
redneck17
Oct 29, 2015 09:09 PM
justdifferentials
Just Differentials
Sep 17, 2015 06:14 PM
kirkrunner
Jul 27, 2015 07:59 PM
greenbuggy
3.4 Swaps
Jul 23, 2015 11:51 AM
