stuck in 4wd after diff and tranny swap
Old Sep 21, 2011 | 09:50 PM
runs-on-4's Avatar
i have had a lots of problems after i swapped trannys. i went from just having no reverse to have a tranny that works in all gears just makes a whinning noise in everyone expect for 4th. then i blew my rear diff and thought i had a welded 410 spare diff but its not. i put that in not checking and the front wheels skid on pavement in 4wd. i also could not get out of 4wd. for the longest time, this happened once with my old trans and tcase. what could cause this
Old Sep 26, 2011 | 10:36 PM
mommucked's Avatar
Ive had trouble shifting out of 4wd before and shifting into reverse and backing a little usually lets me shift out of it. Are you sure the shifter is installed correctly? Tcases that sit for a long time become hard to shift. I know, I just installed one! I put a gob of grease on the TF shifter and worked it through all shifts a few times and it is much better now.
Old Sep 27, 2011 | 01:41 PM
peow130's Avatar
Well, start by putting the trans in reverse and letting the xfer case un-bind before you grenade it.
Second off.. unlock your hubs..
third off, make sure your diffs match.
Old Sep 27, 2011 | 03:02 PM
rokblok's Avatar
If you do demolish the t-case, or either diff, please post pics....
Old Sep 27, 2011 | 03:49 PM
runs-on-4's Avatar
ill be posting pics of my last diff that went bad, soon. as for being stuck, it just kinda fixed its self, i believe since the tcase was sitting for awhile, it just kinda binded everything up but its up and going now
mskalmus
May 28, 2017 07:51 AM
jerusry
Oct 19, 2015 05:28 PM
Iceman4193
Jul 15, 2015 04:48 PM
TokyoD23
Jul 12, 2015 06:01 AM
madxman21
Jul 9, 2015 10:26 AM
