booster
Old Jan 26, 2008 | 06:23 PM
84yota4x4's Avatar
Lightbulb booster
so i need some advice. im replacing my brake booster and putting the pin in is a bitch .....are you supposed to have to push the rod in to align the holes? or is it supposed to line up easily?
Old Jan 26, 2008 | 06:30 PM
myyota's Avatar
Are you talking about the pin for the brake peddle ?, if so then just move the peddle as needed to get the pin to slide in.
Old Jan 26, 2008 | 07:11 PM
84yota4x4's Avatar
how do you adjust the pedal?
Old Jan 26, 2008 | 08:12 PM
myyota's Avatar
Is the booster new or did it come out of another truck ?, if it came from another truck you shouldn`t need to adjust anything, it should just bolt in. I put a duel diaphragm brake booster in my 84 4Runner about a month ago, it came from another truck and it just bolted in, no adjustments needed. if it new you might need to adjust it a little, but i can only guess with out seeing it.
Old Jan 27, 2008 | 09:56 AM
84yota4x4's Avatar
it is new..do i adjust the brake light switch?
4.34runner88
Feb 7, 2016 02:24 AM
Lons81
Nov 23, 2015 09:25 AM
zanzabar0
Oct 11, 2015 02:56 AM
Draven023
11
Oct 1, 2015 06:47 PM
user 82300
Sep 15, 2015 05:49 AM
