Radiator and Electric Fan Set Up
Old Mar 2, 2024 | 11:00 AM
Boogeyman's Avatar
I bought a radiator and black magic electric fan from LCE. I was trying to see if everything would fit and it looks like the ac compressor is in the way. Does anyone have experience with this set up?
Thanks
Old Jul 29, 2024 | 06:20 PM
TheAxialNut's Avatar
did you ever get this figured out?
Old Jul 30, 2024 | 04:49 AM
OldBlueMidnight's Avatar
5 Year Member
I ran that setup for a while. No ac, and fit wasn't a problem, but the probe that sits in the radiator fins was, and the electrical draw would tank my idle too much. It worked better with a bung added to the radiator for a proper temp sensor and a soft start controller, but cooling performance was never very good, so I ditched it.
Old Mar 18, 2025 | 04:06 PM
Boogeyman's Avatar
it looks like there’s a 90s 4Runner AC set up installed so the compressor gets in the way. I just wound up using a flex fan instead.
i put the electric fan on my 86 pickup. It fit perfectly
Old Mar 18, 2025 | 04:09 PM
Boogeyman's Avatar
Bummer. We’ll see what my results are. Just need to figure out how to wire the power to the ignition source it shuts off with the vehicle
Old Mar 24, 2025 | 04:39 PM
Boogeyman's Avatar
To anyone interested:
I wound up installing this set up in my 1986 pickup. I have everything nicely wired up but my only hang up is finding a “12v keyed ignition source” that connects 12v to the “+” terminal on the fan. This ensures the fan shuts off when the key is turned off.
I need to jump onto a fuse that only lights up when the key is turned on. So my question is this, is there a way to jump it off the fuse box under the hood? Or do I have to run the wire through the firewall and hook into the ignition fuse on the fuse box by the driver’s left foot. Any thoughts or better ideas? Thanks.
Hairyberry
Apr 22, 2023 09:42 AM
customdrum
May 25, 2015 07:49 PM
greenz02
Oct 18, 2011 12:14 PM
sniper626
Jan 14, 2007 03:32 PM
2wheeler97
Nov 14, 2002 08:37 PM
