85 4runner sitting for over 10 years Q&A
My dad has a stock 85 4runner in great condition that has not been running for about 10 years. good news it has been sitting in a garage for the last 7 years. He is going to buy a new motor but what i would like to know is what all other parts he should buy to make it his daily driver. I know new tires, brakes, lines, and servicing the axles and draining fuel tank. What else should he do to make it a daily driver? Any help would be appreciated!
I would flush the radiator an put a new themostat if it has sat that long i would imagine the radiator has built up sum gunk over the years an the old thermostat is probably stuck open or closed. Could save you a blown head gasket in your new motor
Hello, welcome! First I would download the FSM (factory service manual), you can get it free. This truck has the potential to be a great DD but you will have your work cut out for you. Seals dry out in time and cause leaks and leaks can lead to other problems. FSM will give you factory how to which is far superior to Haynes or Chilton.
x2 on what was said above. About fluids, belts, and hoses. I wouldn't swap engines until you try it. A factory motor is superior to a rebuilt and may only need a few easy to replace gaskets. This is my two cents, the truck will require elbow grease and basic know-how.
Anything that touches gas. And if you keep the motor it wouldnt hurt to have it bored out. What caused it to stop running 10years ago?
MMA_Alex
25
04-18-2017 05:07 AM
FS[SouthEast]: Mercury Villager Fan & DCC Fan Controller
coryc85
09-09-2015 06:24 AM
