Oil sending unit ?
Old Jan 13, 2013 | 07:29 AM
marmon77's Avatar
Oil sending unit ?
I put a new gauge cluster in my sons truck,an '85' 4Runner 22RE, this one has the amps, temp,fuel and oil pressure. My question is where do I hook the sending unit up to and then where does the wire go or how does it connect to the gauge in dash? Thanks
Old Jan 13, 2013 | 08:46 AM
waskillywabbit's Avatar
If you had the old style then you had an oil pressure sending unit that just tripped a light. The newer gauge cluster actually registers pressure so you need the other type sending unit.
:wabbit2:
Old Jan 13, 2013 | 02:30 PM
marmon77's Avatar
Ok, I have that, he sent it with the cluster. So I just change out the sending unit and I'll be fine?
Old Jan 13, 2013 | 02:54 PM
SPARKS89's Avatar
You shouldn't have to do anything else once you change out the sending unit.
Old Jan 13, 2013 | 02:58 PM
marmon77's Avatar
Ok excuse my ignorance is there a wire already connected to the original one and I'll just remove the wire change out the sending unit then reconnect the wire?
Old Jan 13, 2013 | 03:55 PM
SPARKS89's Avatar
Yes. It's right underneath your oil filter. Just pull the connector off and swap out the sending unit. It should be a 14mm wrench. The connector will slide onto the tab on the new unit. It doesn't plug straight in like the old unit. You'll see the notch on the connector when you take it off and it'll make sense then.
Old Jan 14, 2013 | 04:27 AM
marmon77's Avatar
Ok I appreciate the help!
Doug4320
Mar 24, 2018 10:11 PM
gary4runner
Sep 24, 2015 12:53 AM
skoti89
Sep 11, 2015 07:46 AM
Odin
Jul 15, 2015 09:28 PM
Tyler Cunningham
Jul 11, 2015 10:18 AM
