Rubber hoses 22re
Old Jan 27, 2013 | 01:28 PM
LT1UltraZ's Avatar
Rubber hoses 22re
Does anyone have part numbers for all the hoses on a 85 22re?
and can i get them all at autozone, or do i need to order some from the dealer.
I have the engine out right now and i would like to change all of them out.
Thanks!
Old Jan 27, 2013 | 08:45 PM
Vang530's Avatar
there are no part numbers if you are talking about the vacuum hoses...they sell them in bulk at major auto parts stores...just bring a sample of each different size and how many feet you need.
Old Jan 28, 2013 | 01:43 AM
LT1UltraZ's Avatar
i am not talking about the vacuum lines.
Upper radiator hose ----autozone
lower radiator hose----autozone
waterpump to block?
hose from the head to the block?
what about hoses from the air bypass valve?
i am sure i am forgetting few
Old Jan 28, 2013 | 07:03 AM
ncjeyota's Avatar
Try Rockauto.com, they should have all the hoses you need and are priced reasonably.
Old Jan 28, 2013 | 07:23 AM
AssYriaNrocKer's Avatar
PCV vent hose - 12262-35060
Thats the only hose part# I have right now... lol
If it has been a while since you have changed the pcv valve I would replace both hoses, the valve and the grommet.
PCV Valve - 12204-35040
PCV Grommet - 90480-18180
-RONI-
Old Jan 28, 2013 | 08:01 AM
snobdds's Avatar
Go to toyotapartseast.com, enter your vin and be your own parts man.
All the weird hoses, under the throttle body will be in the fuel injection section. Weird, I know.
Get the correct toyota hoses, it will make your life a whole lot easier. Also, get the factory clamps with the pull tab. You can thank me later.
montanatruck
Feb 26, 2017 07:07 AM
94 Newbie
Aug 6, 2015 10:33 AM
jjrbus
Jul 19, 2015 02:06 PM
redghost.308
California SoCal
Jul 16, 2015 07:46 AM
Fundy Rider
Jul 16, 2015 01:35 AM
