84 carbed 4x4 will not start
Old Nov 14, 2012 | 01:25 PM
ihuntsum's Avatar
New to me. Was running yesterday. Will not start today even with starting fluid. Spark thru all spark plugs when grounded. Where do I start?
Old Nov 14, 2012 | 02:15 PM
'884Runner's Avatar
Is it getting any gas to the carb?
Old Nov 14, 2012 | 02:19 PM
ihuntsum's Avatar
Pretty sure gas to carb no pop even with starting fluid
Old Nov 14, 2012 | 06:04 PM
slow-mo's Avatar
Originally Posted by ihuntsum
Where do I start?
Start with the basics:
Fuel?
Air?
Spark? - good as you say.
then
Compression?
Timing?
Better yet, start with the diagnostics in the factory service manual (FSM).
Old Jan 5, 2013 | 02:09 AM
noodle85yoda's Avatar
slow-mo is right, all you need to make a engine run is spark, fuel and air, is you have all 3 look for something mechanical.
best of luck
Old Jan 6, 2013 | 01:41 PM
toyquad's Avatar
actually timming is also needed to make the engine start. give the engine all the fuel, air and spark you want, but if the timming isnt correct it wont start.
check and make sure coil wire is on correct.
pull valve cover and dist cap, ensure timming chain is intact, and that the timming is still correct.
inspect cap, rotor, plugs etc
Regency
20
Jan 3, 2020 07:43 PM
Jnkml
Jul 6, 2015 01:20 PM
bigblue82
10
Jul 6, 2015 08:27 AM
toy89yota
Jun 24, 2015 01:18 PM
