85 Skyjacker 5" kit with rear leafs
Old Mar 22, 2013 | 04:28 PM
91lux's Avatar
I have a 1991 double cab Hilux Pickup SFA. which uses identical suspension amd steering (except its rhd) to the 84/85 sfa pickup. I am currently running the $400 rough country 3" kit with rear leafs and its already sagging badly. I can't afford the TG weld on kit or the labor rates of installing it. So I was thinking of going with the 5" Skyjacker kit and either paying for crossover steering or a adjustable drop link. Does anyone have any first hand experience with this suspension setup with the crossover steering or with a drop drag? Any problems with install or any performance issues? Do the shims properly correct the Diff angle? I am aware it is going to flex and ride like crap. Thanks for any insight
Old Mar 22, 2013 | 05:48 PM
854x4's Avatar
I have this kit on my 85 LHD truck but I have a 3/8 spring pad spacer installed on my driver side to make the truck sit level and with this setup you will have to modify the steering arm "flip ball" to make a drop draglink work or leave the spacer out and you should be fine. Also take the shims out of the front packs. I ran mine and the steering was terrible so I took them out. They are there to correct the pinion angle but they screw up your caster angle. I think they were 4 degree shims that came on my skyjacker pack. I'm running 5" skyjacker front leafs with stock shackles and rear leafs with 1.5" lift shackles and I'm happy.
Old Mar 23, 2013 | 06:52 AM
91lux's Avatar
Thank you very much that is very helpful.
Old Jul 9, 2013 | 08:44 AM
myyota85's Avatar
85 4x4 you still happy with the 5" skyjacker leaf's up front?? im looking at buying them also..
88sasturbotoy
Jan 30, 2026 01:57 PM
Flying91
45
Apr 11, 2024 04:39 PM
XtraCab
Apr 12, 2020 05:25 AM
jerusry
Oct 19, 2015 05:28 PM
Nickdigg
Jul 7, 2015 06:04 AM
