can't get into gear
Old Mar 6, 2013 | 07:11 AM
colorado85pu's Avatar
can't get into gear
just bought an '85 5-sp pickup
shifted fine when i got it but it's been sitting for a spell and
seems maybe clutch fluid has leaked out?
i topped off what i believe is the clutch fluid res and it has sat for a while but
i don't know how to bleed it yet.
when i step on the clutch there's no resistance at all and can't shift into any gear.
tranny grinds if i try to get into reverse.
haven't found a repair manual yet so thought i'd see if i could get some help here.
thanks
Old Mar 6, 2013 | 08:02 AM
4Crawler's Avatar
Clutch slave cylinder is on the passenger side down behind the starter. Have someone press the pedal down while you watch the slave cylinder and see if it is pushing on the release lever visible outside the bell housing. If not, then it is either the slave or master cylinder. For the master, it usually leaks brake fluid down under the floor mats. Both are fairly easy to replace except a bit hard to access. Bleed by cracking open the hardline at the m/c while pressing the clutch pedal down.
Old Mar 12, 2013 | 06:24 AM
ok, so i spent a bit more time looking things over and as far as i can see there is no leak and fluid level is good. when clutch pedal is depressed there is almost no movement at all of the lever at the bellhousing.
before i start replacing the hydraulics, is there a way to test/adjust the mechanism between clutch pedal and master cylinder?
thanks
mskalmus
May 28, 2017 07:51 AM
norcal98
Aug 10, 2015 06:20 AM
wolfpackfan33
Aug 2, 2015 03:36 PM
Shaun Crystal Gomban
Jul 30, 2015 10:13 PM
justdifferentials
Just Differentials
Jul 22, 2015 08:26 PM
