needing some help with brakes
Old Feb 23, 2013 | 05:18 PM
voodoo69's Avatar
so i have a 1984 yota that i have mono linked in the rear with fox air shocks. so there are two braks lines going back to a lspv. i dont wont to run the lspv. i would like tp have a single line going down my link stright to the rear end. so what im askin is how do you bypass lspv.
Old Feb 24, 2013 | 03:21 AM
rokblok's Avatar
Install a proportioning valve somewhere in the rear line.
Old Feb 24, 2013 | 08:55 AM
TOYROX's Avatar
I removed my lspv and blew the seals in my master first time I hit the brakes. You need a proportional valve. What I ended up doing was building a bracket with a screw adjustment for the top of the stock valve and mounted it under the hood. Then just run your one line back.
BigArt70
Jun 30, 2015 09:51 PM
DanStew
Jun 29, 2015 10:46 AM
LSUMatt1514
60
Oct 10, 2003 12:30 PM
HALMAN
Jun 14, 2002 09:02 PM
