Compression test...one cylinder down..leaking head gasket... rebuild or not
well i think i figured out why my truck did not want to start when it is warm. Turns out i have a head gasket leak. I did a compression test and the numbers are
Cylinder 1........145
Cylinder 2........120
Cylinder 3........150
Cylinder 4........152
I did the wet test as well but the numbers were all over the place...i dont trust the gauge i got from autozone..the wet test numbers were
Cylinder 1........210
Cylinder 2........150
Cylinder 3........240
Cylinder 4........210
here is the leak...it is directly under cylinder 1 exhaust port, now how come it's cylinder 2 that is down on compression instead of number 1? Also whoever adjusted the valves before me set them too tight, i cant fit .12 on the intake nor i can fit .08 on the exhaust without forcing it in...will that effect the compression numbers?
Now for my options. Should i just throw a new head gasket on there and call it a day? The truck has 120k or so on it, doesnt smoke , and runs great even with the head gasket leaking.
The timing chain has been changed out not too long ago, the plastic guides are there
well i took the whole engine apart, turns out whoever did the HG/Timing Chain job aprox 5k miles ago didnt know what there were doing.
Used all new OE Parts (water pump/oil pump/clutch) but used some cheapo head gasket
the1998sr5
15
Jul 14, 2020 08:35 PM
jerusry
Oct 19, 2015 05:28 PM
