1985 22RE Running rough
Old Feb 26, 2013 | 06:32 AM
marmon77's Avatar
Hey guys, heres's my problem. Truck will be runninig along fine then for no apparent reason it acts like it bogs down starts "bucking" real bad and back- firing. I can push in the clutch and it will rev with no problem but when I let the clutch back out and start to accelerate it will start "bucking and back-firing again. It did that for about 10 mins. then it stopped and I could go thru the gears with no problems. I've replaced the plugs, plug wires and the fuel filter and still having problems. You're thoughts are appreciated! Thanks
Old Mar 1, 2013 | 10:19 AM
marmon77's Avatar
Well I ran some gas treatment with water remover thru the tank and so far haven't had the rough running that I was experiencing. Hopefully water in fuel was the cause!
Old Mar 5, 2013 | 06:54 AM
ojm3's Avatar
my advice stop using ethanol pump gas and run no ethanol fuel. that or run 89 octane and seafoam constantly
Old Mar 5, 2013 | 07:31 AM
Tonka toy23's Avatar
Im having the same problem my truck wont go pass 35 mph without bogging down I ran out of gas one day and ever since then its been running lk crap I added some fuel treatment still no help anybody got any ideas ?
Old Mar 5, 2013 | 07:45 AM
StewsRunner's Avatar
I would change your fuel filter. When you run out of gas you suck up all the dirt/dust etc. that is lying at the bottom or your fuel tank, It may be clogged.
Old Mar 5, 2013 | 07:56 AM
I changed fuel filter I had an intake leak fixed that as well and still no good I might of clogged the Carb what do you think?...i notice my truck runs worst when it warms up and my spark plug wires are extremely hot but plugs look good I havent changed those since I got the truck last year
Old Mar 5, 2013 | 08:30 AM
Wyota's Avatar
I just dealt with a similar problem on an 85 runner (22re). It would start and run, but wouldn't hold idle until it got warmed up (even then it would often die). Bogged down like crazy while driving around town.
My fuel tank was glazed and filthy, the fuel filter needed replaced, the injectors were filthy, and I had a loose intake, so air was sneaking in after sensor. now it runs ok, but will need to do something about the tank as it will repeat the problem if not cleaned out
Old Mar 5, 2013 | 08:31 AM
ojm3's Avatar
I'd say soo bud...looks like its time for a rebuild
Old Mar 5, 2013 | 09:32 AM
ojm3's Avatar
Old Mar 5, 2013 | 09:39 PM
Looks lk im going to rebuild Carb going to run new fuel lines clean out gas tank I did that to my 82 yota never had no trouble with Carb after that.
Old Mar 6, 2013 | 03:37 AM
ojm3's Avatar
sounds good. great idea on the lines
MO transplant
Apr 23, 2023 11:58 AM
jbv808
Aug 6, 2021 04:47 PM
Colington
Mar 8, 2020 09:51 AM
bryan34w
Jul 6, 2015 05:53 PM
karbin
Jul 5, 2015 11:37 PM
