Vacuum Line Help! (PICS)
Old Jan 1, 2013 | 12:09 PM
MATTSRED's Avatar
Hey installed a stock carb today and followed a diagram pretty well, but I have a couple im sort of lost on, If you could help me out it'd be great!
First I do not know where these two go??
Second
Third ( Also am I missing something off this carb in the yellow circle??? )
Fourth ( Yellow circle that one is capped do i need it? )
Old Jan 1, 2013 | 01:29 PM
phildelfino's Avatar
this might help.
https://www.yotatech.com/forums/f114...ly-22r-205845/
https://www.yotatech.com/forums/f116...-lines-263333/
Old Jan 3, 2013 | 05:01 PM
ojm3's Avatar
#1-the blue plasic- charcoal cannisters...forget em
#2- wouldnt worry bout it
#3- shouldnt be a vacuum line, should have small cut out like place for flathead screwdriver/ also dont think anythings missing
#3b- lower larger opening goes to a hose leading to some type of smog valve inside of your air cleaner box, i have mine capped off due to weber carb
#4- yes they were both capped off on my stack carb as well
If you do not have a line hooked up it MUST be capped off just to be safe. I got a friend who de smogged his truck, installed a new weber n wha not and now he has a vacuum leak from hell and cant figure out what he can and cannot cap off.
Old Jan 3, 2013 | 08:26 PM
slow-mo's Avatar
Well, first of all, even though you state that you are in California, looking at your first pic, your vehicle does not look to be a California emissions engine.
So...
As was stated, that's part of your EVAP system. Once the computer senses a specific temperature via one of the coolant sensors, the computer triggers that switch to draw out the stored evaporated fuel in the charcoal canister. The charcoal canister vacuum lines are plumbed in with the intake manifold.
Second
That is part of the engine's Hot Air Intake (HAI). It aids in the driveability of a cold engine.
There's a vacuum hose that runs from it to the underside of the air cleaner. In the air cleaner there's a thermo-switch that senses the intake air temperature and controls the bellow door within the round HAI to divert hot air collected from the exhaust manifold shroud.
The port in the top circle should be plugged. I don't have that port & mines a Cali truck, albeit an '87. I'm not entirely sure what that port is for.
Middle yellow circle: that's just the casting in the carburetor for the older Aisan carbs. The early 80's 22R carbs used a Hot Idle Compensator (HIC) to aid in hot engine restarts. Toyota did away with it, but they did not change the casting. They did plug the internal vacuum passages, though.
Bottom circle pic:that where the PCV rubber hose connects to. The PCV is on top of the valve cover.
Those two ports are used for California emissions. The Electronic Bleed Control Valve (EBCV) vacuum lines are connected to those two carburetor ports to add air when the computer detects a rich mixture via the oxygen sensor.
Wait a second....do I see an oxygen sensor in picture 2?
Old Jan 4, 2013 | 04:02 AM
ojm3's Avatar
I'm fairly new to yotas and I mean you no disrespect slo-mo. but are you sure carburated engines would use an o2 sensor? I've not found one on my 84.
Old Jan 4, 2013 | 08:11 AM
slow-mo's Avatar
Only the California (50-state) model uses an oxygen sensor. Neither the Ferderal (49-state) or Canadian versions use the o2 sensor. The California-spec carburetors are a feed-back version of a carburetor.
It was because California was/is more strict in their emissions control.
Had to make a correction when I said 48-state. haha
Old Jan 4, 2013 | 08:13 AM
ojm3's Avatar
thanks for the info slo-mo
Old Jan 4, 2013 | 09:27 AM
slow-mo's Avatar
Well I messed up my first post I made this morning. I thought I clicked "quote", but I click "edit" instead.
So...
Originally Posted by slow-mo
I do know what that vacuum port is. There's a vacuum plasitc T-connector that goes from the Bi-metal Vacuum Switch Valve (BVSV) to the Auxiliary Accereration Pump (AAP) and the Choke Pull Off. Or from the BVSV to the Choke Breaker. One of the vacuum lines from the T-connector goes to this port. I can't remember specifically which one it is, but is basically serves to relieve vacuum flow because what is connected to it is always under vacuum pressure.
I found out that port does go to the plastic T-conector, which goes to the BVSV.
icentropy
Sep 16, 2020 02:47 PM
Poppie51
Jul 23, 2015 05:03 PM
Poppie51
Jul 16, 2015 06:16 PM
jgwerth
Jul 16, 2015 03:23 PM
TokyoD23
Jul 12, 2015 06:01 AM
