"Popping" noise when turning.
I had a popping noise and feel when making turns, thought it was the king pin bearings. Got a knuckle service kit, did the work, still have the pop! Everything was done to spec, but I do have a 3" lift and 33"s. I know when you modify you change geometry, Anyone had the same problem?
Maybe tires rubbing. Or some kind of steering stop issue. Not 100% on solid axles...tires got chew marks in them? Like getting into your sheet metal?
Birf looked good! I looked at everything, I wanted to be in there one time in ten years, thats it. Hate front ends. Did the brake pads; didn't even need it..
zytra
01-24-2019 03:16 PM
zombie_barbarossa
10-02-2015 10:54 PM
