Truck just died!!
Old Apr 30, 2013 | 03:47 AM
marmon77's Avatar
Truck just died!!
My son has a 1985 4Runner with the 22RE he was on his way to school this morning and the truck just died. He started it back up it shut off again and now wont start. It's been running fine. Any thoughts would be appreciated truck is sitting on the side of the road. This just happened . Thanks
Old Apr 30, 2013 | 04:14 AM
marmon77's Avatar
Gonna pull the fuel line off and make sure the fuel pump is working.
Old Apr 30, 2013 | 10:01 AM
Terrys87's Avatar
Sounds like it is on the fuel side the other would be on the firing/spark side. I would suggest pulling the fuel filter and see if you can get air thru it. They get plugged up really well.
If you can get air thru the filter, start looking at the fuel pump. This being your sons truck, does he run it on empty all of the time? Fuel keeps the pump cool and if he has been running on empty, it could be a fuel pump just overheated and worn out.. I would do several checks before replacing the fuel pump. Toyota wants about $300 for a fuel pump. Parts stores want about $150. I have gotten great replacements off of ebay for $30 shipped.
Old Apr 30, 2013 | 10:16 AM
marmon77's Avatar
Ok, Terry Thanks, will check fuel pump, and yes he drives it on empty alot.Guess I need to give him gas money sooner. LOL
Old Apr 30, 2013 | 10:22 AM
Terrys87's Avatar
LOL...I would bet it is the pump. Let him know to atleast stay above an 1/8th tank. I fill up at 1/4 tank.
It has been a while since I trouble shot a fuel pump. Seems like I proped the AFM flap open and then disconnected the fuel line off of the back of the fuel rail and ran it to a jar and turned the key on.
When a truck is running, it will fill a quart jar in about a minute or so for a rough guess, you will know if it pumping enough fuel.
On my 88 thread below, on the first page, I have a link to ebay fuel pump. It is about $5 doallars cheaper if you call them as they dont have to pay their sales percentage.
I have had great luck with those fuel pumps. One guy did say his wasnt an exact fit, but of the 6 I have used on 6 different trucks, they look and fit just like a factory one and you wouldnt be able to tell the diffence.
Old Apr 30, 2013 | 11:40 AM
Redeth005's Avatar
This happened to me with my motor. Although I do not have the 22re it did happen on my 3vze. My problem was that the main distributor cap cable came undone. Might be the be for you?
Old Apr 30, 2013 | 11:53 AM
se7enine's Avatar
If you plan on getting a fuel pump then I suggest you get it directly from DENSO or SparkPlugs.com. Cheaper then dealer. More auto part stores are starting to carry denso now though.
Old Apr 30, 2013 | 12:29 PM
marmon77's Avatar
I had my son pick one up at autozone along with the strainer. He's gonna try and put it on before I get home, hopefully its pretty straight forward.
Thanks for the help and info.
Old Apr 30, 2013 | 12:55 PM
snobdds's Avatar
Slow down there and do a little more troubleshooting before throwing parts at it. There is a way to turn the fuel pump on by jumping a couple of terminals in the diagnosios box, however your's is an 85 and the procedure is slightly different. Search for it on 4crawler's site and you will find the procedure. This will tell you if your pump is good or not.
Next check for spark...autoparts stors sell spark testers for cheap.
Next check to make sure the AFM flap is operational and not stuck. The AFM actually gives the signal to the ECM to turn of the fuel pump. Search for the test to make sure the AFM is good.
Then you buy and replace what is broken...
Old Apr 30, 2013 | 01:53 PM
RAD4Runner's Avatar
Originally Posted by snobdds
Slow down there and do a little more troubleshooting before throwing parts at it..
Agree with snobdds. From above, P.O. has not tested for spark, nor specified what "wont start" means. What are the symptoms? Testing for spark is easier done with less tools than testing for fuel flow/pressure.
Old Apr 30, 2013 | 01:57 PM
marmon77's Avatar
It was running and shut off the my son restarted it and then it shut off again. Now it won't start
Old Apr 30, 2013 | 03:23 PM
marmon77's Avatar
Ok so he got the fuel pump on and got it started. It revs up fine in neutral but when he goes to drive he can't get ovet 2000 RPM with out it breaking up. it's hesitating badly under load. Any thoughts?
Old Apr 30, 2013 | 03:26 PM
marmon77's Avatar
He's checked for air leaks, checked plug wires and connections they're all good.
Old Apr 30, 2013 | 03:42 PM
B-Fake's Avatar
Did he get it home? Maybe check the TPS. Another thing that's relatively inexpensive and could help is replacing the ignition system; plugs, wires, cap, and rotor. Mine never died, but it did all of a sudden start missing and acting very sluggish and new ignition components had it running like new. Testing the AFM would be a good idea too.
Old Apr 30, 2013 | 04:01 PM
marmon77's Avatar
Yes he got it home. We just changed all that out a few months ago but I guess could dom it again just to be sure. How would I go about checking the TPS and the AFM?
Old Apr 30, 2013 | 07:07 PM
B-Fake's Avatar
This should get you going in the right direction.
http://www.4crawler.com/4x4/CheapTricks/TPS/index.shtml
http://www.4crawler.com/4x4/CheapTricks/AFM/index.shtml
Probably more info than you'll ever want to know about either .
Old Apr 30, 2013 | 07:10 PM
B-Fake's Avatar
Oh, and if the ignition stuff is that new it is probably fine, I'd just check the cap and rotor for corrosion and make sure the plug wires are making good contact.
Old Apr 30, 2013 | 07:19 PM
codyarmbrust's Avatar
I am sorry for jumping into this thread but new to site and wont ˟˟˟˟ing let me sdtart my own anyways complete rebuild on 89 toyota pickup 3.0 now it just idles and when you give it gas it just wants to die fir a second than idles up this truck starts good and idles good just wont rev timing is exactly 12 degrees btdc using timing light tried ten and does the same thing i used the vacum diagram and everything is right new cap and plugs and wires please help
Old Apr 30, 2013 | 07:51 PM
SoCal4Running's Avatar
For us on Mobile Devices who can't see your location, where are you at?
Their might be someone close to help diagnose the problem.
Old Apr 30, 2013 | 08:00 PM
athol idaho i am a mechanic as well but generally do n ot work on toyotas mainly diesels anyways its got to be something simple all lines are in the original location double cheched using schematics and diagrams i am throwing 20 codes ranging from knock senor to intercooler wich it doesnt have truck ran with the last motor in it this one just idled and starts great but that is it timing is on tried adjusting tps still nothing air filter is proporly installed any ideas and how do i start my own thread
