Throttle sticking.. Gas pedal?
Old Apr 30, 2013 | 07:51 PM
YotaInSC's Avatar
My throttle hung up at 5000 RPMs while going down the road. I cut it off and pulled over. Got out and popped the good and the throttle cable looked fine to me. I pulled back on the gas pedal, crunk it up and it idled fine. Now, any pushing on the gas pedal (even just a hair) and it sticks. I have to put my foot under the pedal and slightly pull back before I press the clutch in. Any ideas on this?
Old Apr 30, 2013 | 09:46 PM
SoCal4Running's Avatar
Carpet, floor mat, insulation or nearly frozen pivot at the gas pedal hinge above your foot.
Old May 5, 2013 | 09:23 PM
the_supernerd's Avatar
Maybe a broken spring in the throttle pedal? Or it could just need some WD-40.
Old May 5, 2013 | 10:32 PM
wyoming9's Avatar
Red face
Cables do wear out!!
How does the linkage work if the cable is disconnected ??
have you looked in the cab to see if something is causing this problem like was said.
When was the last time the linkage was lubed.
Why did you have the engine rpm so high??
Old May 6, 2013 | 08:00 AM
highonpottery's Avatar
inspect all of what has been suggested already, but also check out your intake and make sure it's nice and clean. when i got my truck, the PO never cleaned the intake and the butterfly was caked with carbon - causing the pedal be hard to depress and restricted how fast it came back up. at least you'll have a clean intake if it's not the problem
Old May 7, 2013 | 09:49 AM
ojm3's Avatar
Def check the butterfly! Then lube your linkage
Old May 7, 2013 | 09:59 AM
bruno4turbo's Avatar
def check every thing above ^^^ and also check the spring the throttle cable connects to as well, mine was super gummed up (still have to clean it all the time) and my pedal was hard as a rock and super slow to return usually used my foot under it to push it back up, also why so high?? you're gonna blow the head like that lol
Old May 7, 2013 | 10:07 AM
ojm3's Avatar
Definitely keep it under 5 grand besides formula cars and street bikes not too many inline engines like high rpms
Old May 7, 2013 | 10:19 AM
yea, street racer keep them under 4. between 4 and 5 is HG kill zone... unless you're doing a hill climb when off roading, and even then, don't do it very long.
Old May 7, 2013 | 10:39 AM
ojm3's Avatar
Yes sir good advice there! I don't dog it for more than 5 to10 seconds when hill climbing. There really is no need to go over 4 grand unless you built a race machine. If I'm not mistaken the 22r starts to diminish in horsepower and torque at about 4 grand anyways so no need to run it that high
Old May 7, 2013 | 10:54 AM
20r, 22r, 22re, even the v6 as well, these engines have low end torque, after 4k you're just wasting fuel and risking lotsa $$$, learn from this my mistake on not listening about how sensitive these engines can be, they're tough, but do need to be respected
(also "ma'am" is more appropriate than sir personally)
back on topic... best way to clean your springs and linkage is use brake parts cleaner and a tooth brush, then oil it, use engine oil not WD-40, tho WD-40 is fantastic, it does go away with heat after some time, and then your linkage will be dry
Old May 7, 2013 | 11:19 AM
ojm3's Avatar
Yes ma'am haha
Old May 7, 2013 | 01:50 PM
warpigg's Avatar
could also be a vacuum leak my celicas throttle stuck because I have a supra throttle body and it didn't seal correctly so I had to put rtv around it and it fixed my problem
Old May 7, 2013 | 04:27 PM
i agree that a vacuum leak would purpose a problem, but then he would probably have brake problems. how do your brakes feel? if they're hard (no assist) then its deff a vac problem. also since vac line is under a dollar per foot its nice if you get all new, then you don't have to pinpoint a leak lol
ps - get 2ft more than you think you'll need, you'll be surprised on how much you'll actually need haha (i needed over 6ft, but i wanted more slack in some areas)
Old May 8, 2013 | 04:25 AM
warpigg's Avatar
I had a vacuum leak on my intake plenum where my throttle body is and I never noticed hard brakes or anything I wasnt driving the car enough when it was throttle was sticking to notice
Old May 8, 2013 | 07:55 AM
it does depend on how significant the leak is, and where the leak is coming from. but brake boosters work off of vacuum assist, if theres not enough vacuum to assist a hard pedal occurs. it might not be that significant of a leak to be bothering the brakes enough to notice, doesn't hurt to check tho
Old May 9, 2013 | 06:28 PM
YotaInSC's Avatar
Sorry guys. After about thirty minutes, I found the problem.
smthwsn357
May 1, 2024 07:28 AM
Blamalam
Mar 12, 2022 07:34 AM
HollieJayyy
Aug 9, 2015 07:59 AM
D.B.T. 87 4x4
Jul 20, 2015 04:51 PM
smiley52
Jul 11, 2015 05:16 AM
