Third gen 4Runner rims on first gen 4Runners?
Old Apr 14, 2009 | 01:10 PM
Jasper4runner's Avatar
Does anyone know off hand if the third generation (96-later) rims will fit on my 85 4runner? Is the center hole smaller on the newer models?
Old Apr 14, 2009 | 02:48 PM
4Crawler's Avatar
Center hole size should be fine, but the backspacing is deeper, so you would need around a 1.5" wheel spacer to let the wheels clear the steering up front and frame in the back.
Old Apr 14, 2009 | 03:03 PM
lofreqjeff's Avatar
Mine fit perfect on all 4 without spacers when I first put these on. But after installing 1.5" BJ Spacers, the tires were rubbing on the UCA's so I got 1" spacers all the way around for consistancy - These are 15" rims off a Tacoma with 31x10.5 tires. I used a dremmel to cut the hole in the center cap on the front.
Old Apr 14, 2009 | 03:11 PM
4Crawler's Avatar
The IFS ('86-'95) trucks use a wheel with 4.75" backspacing from the factory:
- http://www.4crawler.com/4x4/CheapTri...ne_Pix/24.html
The solid axle trucks use 3-3/8" backspacing:
- http://www.4crawler.com/4x4/CheapTri...ne_Pix/22.html
And that lesser backspacing is needed for the inside of the wheel to clear the steering and brakes up front and the frame in the back, since the solid axle trucks have a 3" narrower axle than the later model trucks.
Old Apr 16, 2009 | 04:26 PM
Thanks for the info everyone, I appreciate it.
Jun 1, 2021 01:51 PM
nick9455649
Sep 11, 2015 05:10 PM
Yotoder865
Jul 9, 2015 07:51 PM
HRDC0R19
Jul 5, 2015 06:43 PM
CJ94yota
Jul 3, 2015 10:14 PM
