85 yota cooling 350
Old Apr 3, 2009 | 05:14 PM
96 ram 1500's Avatar
85 yota cooling 350
hey guys first post want ideas on how to cool it without gettin a fancy radiator i could put the old radiator from the donor truck in the back what would the pros and cons of that b
Old Apr 3, 2009 | 05:32 PM
94toy4x4fever's Avatar
I would just get the rad from the doner truck and fab up some mounts! As long as the old rad is a good one. I have heard that 350's can be hard to cool in a toyota cuz thee isent much room around the engine! I would do a electric fan on that thing! Just my 3 cents!
Old Apr 3, 2009 | 05:37 PM
TOYOTA 1's Avatar
i used a 2 core cross flow rad, with a manual fan.
cooled good.
Old Apr 3, 2009 | 05:39 PM
where you able to fit your radiator up front or in the back the donor truck was a 88 k5 blazer
Old Apr 3, 2009 | 05:41 PM
TOYOTA 1's Avatar
yes, rad was up front.
Old Apr 3, 2009 | 05:48 PM
i dont have room up front to to fit the k5 radiator but could fit one in the back behind or in front of where the fuel cell will set also what fuel cell has the best bang 4 buck would the cab of the 4runner get extremely hot with the doors off
Old Apr 3, 2009 | 05:57 PM
Ron's 85's Avatar
i cut a hood scoop in. and cut some of my wheel wells out. Heat around the headers gets trapped. i also have two 10inch electric fans. make sure your motor in timed correctly cause that can also cause over heating!!!
Old Apr 3, 2009 | 06:06 PM
i got the nwor headers and motor mounts put a 3in body lift in to clear the 700r and am planning on runnin electric fans either way fenders are cut and i will put vents in the hood and heat wraps on the headers ho much heat will the radiator
Old Apr 3, 2009 | 06:07 PM
put out in the back
JonG85
Jan 18, 2023 04:31 PM
TheBFA
Feb 15, 2020 06:55 AM
shredder4286
Oct 1, 2015 01:09 PM
4runnerFireman
Sep 29, 2015 06:24 AM
Matthew Perez
Sep 28, 2015 05:43 PM
