Fixing Load Sensing Proportioning valve ?
Old Mar 10, 2009 | 01:00 PM
littlecommando's Avatar
my rear brakes stoped working and i fixed them, then realized that the Load Sensing Proportioning valve wasnt working, and no pressure was going to the rear brakes. then i found out that no parts stores sell them and its $185 from toyota.
The chiltons guide says that it cannot be rebuilt. is there any way that i can rebuild it? cause im not going to buy a new one at that price
Old Mar 10, 2009 | 02:38 PM
20twinz's Avatar
take it off and put in a pressure regulater right at the brake master cylinder from summit...http://store.summitracing.com/egnsea...4294925134+115
Old Mar 10, 2009 | 03:47 PM
lofreqjeff's Avatar
I have an extra one off an 87 4Runner that had a 22RE - I send you a pm
Old Mar 10, 2009 | 03:59 PM
waskillywabbit's Avatar
I took mine off my 85 ext cab and went rear discs. No idea if it worked or not though.
Try DeathCougar or some of the other used parts vendors. Can't be that hard to find one and I think it is held on with 3 or 4 bolts IIRC.
Old Mar 10, 2009 | 05:27 PM
20twinz's Avatar
Why mine went bye bye....
Its was all locked up like yours is.....
Old Jun 18, 2017 | 07:01 PM
big red 95's Avatar
lsvp
i have an 04 tacoma i just replaced the lspv with a used part had to cut the lines and mak new was wondering if it matters were the feed lines go because i am getting fluid to it where i bleed it but i am not getting any through it to the brakes i am pretty sure it is hooked up right because i marked them befor i cut them any thing els i could check or did i get a bad valve
Old Jun 18, 2017 | 07:04 PM
big red 95's Avatar
lspv
smthwsn357
May 1, 2024 07:28 AM
montanatruck
Feb 26, 2017 07:07 AM
gmonnie123
Jul 26, 2015 02:44 PM
PlayAwhile
Jul 20, 2015 11:36 AM
voiddweller
Jul 15, 2015 03:56 PM
