Brake power booster help?
I have an 82 toy with a small block chevy in it and a power brake booster.I got the truck this way and the brakes just dont seem to be as good as i think they could be.My 87 four runner doesnt take much pressure at all to work.Any ideas on what booster to swap in,what year toyota or what not for better brakes with less pressure.I dont want to dish out cash to get the same as i allready have.Any ideas would be greatly appreciated.P.S. The brake system is all up to par so its not a hard pedal from faulty brakes thanks CJ
Big cam
Its got a 383 stroker in it.I didnt build it so im not sure.Im figuring 390 to 425 horse in her.Doesnt idle radical or anything.Ill check out the reservoir thanks for the reply.
with the added power and weight, u should upgrade your brakes, fj40 rotors with v6 calipers in the front and discs with solid axle calipers in the rear. here is how to do the rear brakes: http://board.marlincrawler.com/index.php?topic=55953.0
A dual Diaphragm brake booster out of a 86-87 turbo truck and T-100's will bolt right in:
The brake booster on 1st gen Trucks is pretty dang small and the brakes suck to begin with and throw bigger tires on there you are stressing a system designs for 225/75/15's. I saw this thread over on Pirate and thought that I would pass it on, relatively cheap and easy upgrade.. Thanks to drsmash for finding a great way to improve some brake systems that are getting old and tired
http://pirate4x4.com/forum/showthread.php?t=689905
part # at napa: both 2 and 4 wheel 532460
the newer booster is a dual diaphram so it should improve braking dramatically.
edit: added Pictures from original thread:
Booster out of a 86-87 turbo model will bolt right into a 1st gen with NO MODS! pure bolt in. I have eldo calipers in back with v6 calipers in front and can lockup all 4 38"swampers on the pavement! Steering clears with no mods to the booster. Just remove the old booster and spacer take off a small spacer that has the gaskets on it and put it on the turbo booster thats it!
Jun 1, 2021 01:51 PM
terminator
Jul 27, 2015 07:13 PM
harrisdawg
Jul 26, 2015 09:42 AM
CanRunner
Jul 20, 2015 01:29 PM
Johntom240
7
Jul 13, 2015 12:18 AM
