Pitch and roll on old 84 2WD
Old Mar 10, 2009 | 04:21 PM
ahickman's Avatar
Got an old 84 2WD 22R and love it. 31 MPG and going strong. Only bad thing is that it drives like a tub of water going down the road. Pitches and rolls even on flat pavement. Hit a turn and it feels like you have the bed full of rocks or water. I have yanked and pulled on every item in the front suspension. BJ's don't budge, tie-rods are tight, front shocks are brand new and have rebuilt the idler arm. Everything seems pretty solid excepting the steering column. I adjusted the screw (1 full turn) on the steering box and this took out some of the play in the wheel. Also noticed that if I yank on the steering shaft, it wobbles at the firewall junction.
As far as the pitch/roll going down the road, what are the most likely causes or things to look at?
Old Mar 10, 2009 | 04:25 PM
slacker's Avatar
check the sway bars
Old Mar 10, 2009 | 04:56 PM
ahickman's Avatar
Don't see a sway bar under it like I have on my 94. I am assuming the two diagonal bars forwards of the control arms are the sway bars?
Old Mar 10, 2009 | 05:09 PM
slacker's Avatar
yep .. I have seen the bolts rusted and loose .. check both ends .
Old Mar 10, 2009 | 05:12 PM
ahickman's Avatar
Confused. Should I crank these down tight at either end?
83yotastockR
11
Nov 10, 2015 06:54 AM
Thamuel_
Domestic Swaps
Oct 3, 2015 11:15 AM
PNW94Runner
Sep 29, 2015 02:55 PM
Cycles
Sep 29, 2015 06:37 AM
potatopants
Sep 15, 2015 06:26 AM
