Need info on 22RE-C Performace Camshafts
Well I am currently in the process of rebuilding my motor for my 85 Pick UP and was wondering where I could purchase a low-end performance Cam Shaft. My driving is mostly for towing and daily driving short distances.
Thanks For Looking
Thanks For Looking
Will do also has anybody heard of
http://www.toyheadauto.com/Performan...alveTrain.html
They make custom camshafts for our trucks any info on this company from anybody.
not sure what they have for the turbo 22RE..but you might check out Comp Cams...type in 22REC or 22RET or 22RTE camshaft..go through the websites it pulls up..thats all i did
you should check out mizumoauto.com im ordering a timing chain kit tha tincludes, waterpump,oil pump.timing cover, timing kit,2 guides,1 cam gear,1crank gear, 1 tensioner (89.95) seems unreal but i'll let you know if it's worth it. they have head gasket sets for 20.95 as well. but as far as cam shafts go i need a lil more power if you find a decent one let me know
when i did mine i pulled the whole head off did the head gasket but i had just recently changed my timeing chain and all my tenchioners so i didnt mess with it. i guess it all depends on what kind of condition its in. if there is allot of miles on it you should just replace it, there really not that that expensive i got my kit from engnbldr.
kawazx636
10-06-2021 03:03 PM
TheBFA
02-15-2020 06:55 AM
buckz6319
08-05-2017 03:50 AM
20r22r, 22r, 22re, aftermarket, cam, cams, camshaft, camshafts, level, perf, performance, shafts, towing, toyheadautocom, trd
