Longblock switch-a-roo
Old Apr 23, 2009 | 06:32 AM
Padawon's Avatar
Hello all.
I am looking into buying a rebuilt long block and installing it myself. The place I am buying the long block from will remove my motor and install the new one for an extra $895. Longblock is $795
I want to save the $895 and do it my self
My question is how hard will it be to do it my self? I did several searches and came up with nothing. What's the hard part? Setting the timing lining up the clutch?
I want to replace the clutch also.
Disassembly
Disconnect harness
Disconnect hoses
Unbolt motor mounts and transmission
Remove old engine
Remove Throttle body/intake, valve cover, header, alternator, water pump, distributor, etc.
Remove old clutch
Reassembly
Replace clutch (need alignment tool)
Install parts on new long block (Throttle body/intake, valve cover, header, alternator, water pump, distributor, etc)
Install engine into the 4runner
Connect hoses
Connect harness
Set timing?
Old Apr 23, 2009 | 07:39 AM
Outsane's Avatar
Sounds good.. just get a manual, and put in new fluids.. new oil filter and all that jazz
Old Apr 23, 2009 | 08:10 AM
Padawon's Avatar
Oh yea forgot about the fluids.
Old Apr 23, 2009 | 08:15 AM
stagger_lee's Avatar
Take pictures of everything as your pulling it out so you know where it goes back in. I'm doing the same thing in a couple weeks. Piece of cake.
Old Apr 23, 2009 | 08:20 AM
algranger's Avatar
Not something you wanna do while installing the motor
Motor swaps are pretty easy in my opinion but some people have a hard time with them. Really its just a few bolts for the bell housing and motor mounts then just connecting a bunch of harnesses and vacuum lines and a few fuel lines. You can find tons of vacuum diagrams here.
If you are going from a short to a long block you will need to convert the alternator bracket or the wiring harness to the alternator.
I pretty well know the vacuum system by heart so if you need some help send me a message i'd be glad to help ya out
Old Apr 23, 2009 | 08:32 AM
Outsane's Avatar
vacuum hoses suck..I still have a great number that are not going anywhere..
Old Apr 23, 2009 | 09:15 AM
Padawon's Avatar
Cool thanks Guys.
Ill take plenty of vacuum hose and wiring harness pictures before I start.
Any opinions on a clutch would be appreciated. Should I go stock or performance?
Or any other sugestions while I got the motor out.
Old Apr 23, 2009 | 09:19 AM
algranger's Avatar
I would definitely go for a Centerforce or Marlin Crawler clutch.. i'm kickin myself for not installing one while the motor was out.
spary_57
Feb 8, 2011 09:27 AM
DupermanDave
Sep 7, 2010 11:10 AM
rowdy235
Jul 1, 2008 09:10 AM
ads86runner
May 9, 2007 02:09 PM
