gears on an 85 p/u
Old Mar 10, 2009 | 01:24 AM
projectyota85's Avatar
Question gears on an 85 p/u
Just bought my 85 p/u and am going from stock tires to 31's and eventually 33's and was wondering what gears i should switch to and get more power yet decent mileage. I live in a town that has numerous hills, must go up one of many to get anywhere.
Old Mar 10, 2009 | 02:48 AM
trdwssrs's Avatar
4.88 would do nicely
Old Mar 10, 2009 | 04:46 AM
MurphyzRunner's Avatar
I have 33's and 456 gears... pro's - can do 75 on the freeway with decent gas milage con's - not low enough gears for rock crawling and steep hills 3 gear, so ya 488 or 529's I'm going to 529's and 35's asap.
Old Mar 10, 2009 | 05:46 PM
86tuning's Avatar
Stock is 4.1 with 29" tires. With 33" tires, you should put in 4.88 if you want the speedo to be accurate. If you want it to drive nicer, you could go as high as 5.29 without problems, other than speedo accuracy.
All that said, I'm running stock gears with my 33's and won't be regearing until I have more funds.
Old Mar 13, 2009 | 06:52 PM
thanks for the info, think i will go with the 4.88s, won't have the money for the 33's until after the 31's wear out
Old Mar 14, 2009 | 12:18 PM
Wardamneagle's Avatar
Since you want to go to 33's then you should go ahead with the 4.88 gears. FWIW, 4.56 gears are perfect for most 31" tires.
MMA_Alex
25
Apr 18, 2017 05:07 AM
Dennisx2
Aug 10, 2015 06:48 AM
Dennisx2
Aug 4, 2015 01:26 PM
justdifferentials
Just Differentials
Jul 22, 2015 08:26 PM
Tyler Cunningham
Jul 11, 2015 10:18 AM
