Leaf springs?
Old Mar 18, 2009 | 12:56 PM
84toyota4x4extcab's Avatar
Leaf springs?
Hey, i was wondering if i moved my rear leafs up front would i have to move the brackets?
Old Mar 18, 2009 | 01:02 PM
flashkl's Avatar
Yes. The rears are a bit longer than the fronts. And I believe the rear leafs are symmetrical while the front ones are a little bit higher on the drivers (?) side, so you're gonna have to either live with that or account for it with a shim of some sort.
Old Mar 18, 2009 | 02:00 PM
4runner Freak's Avatar
What brackets are you talking about?
I have rears up front in the stock hangers with 2" over stock shackles.
I am still running the push-pull steering with a custom drop draglink.
Torque rod had to be removed(or shortened and sleeved).
Old Mar 18, 2009 | 02:05 PM
flashkl's Avatar
Oh cool, I guess the difference in length isn't all that great then. That's good to know. What did you do about the different height springs? Just leave it?
Old Mar 18, 2009 | 02:15 PM
I actually cut down the Toyota overload leaf(It's 3/8" thick) and added it to the drivers side pack.
Old Mar 18, 2009 | 02:20 PM
flashkl's Avatar
Nice. I so wish I had a factory SA...and a crew cab...and no oil leaks...and no bad hg....and no 3.slo...and dual cases....
Old Mar 18, 2009 | 02:30 PM
Stock front springs are 45", rears are 48".
Having banana shackles would help also.
I have welded up a new front spring hanger, but I don't want the extra lift, yet.
4Crawler's Avatar
For the perch height difference, a pre-made spacer is also available:
- http://www.4crawler.com/4x4/ForSale/...ingPerchSpacer
And x2 on the 2" over stock shackle for the 2" longer rear springs (assuming '88/9 or earlier):
- http://www.4crawler.com/4x4/ForSale/Shackles.shtml#FAQ2
- http://www.4crawler.com/4x4/4R_suspe...ideBodyShackle
If you are talking about the '92 leaves, they are longer than that:
- http://4x4spot.com/misc__spring_information.htm
Old Mar 18, 2009 | 02:46 PM
thanks i am planning on doing up the springs this weekend.. ill let you all know how it goes
hiluxinargentina
Sep 30, 2015 05:51 PM
JookUpVandetti
Sep 30, 2015 08:58 AM
Cycles
Sep 29, 2015 06:37 AM
oldblue
Sep 28, 2015 04:07 PM
83
Sep 27, 2015 04:13 PM
