Auto to 5spd - front driveshaft problem. PLEASE HELP!!!
Old Jan 20, 2010 | 05:54 PM
203Cree's Avatar
Okay, went from an auto to a W56 out of an 88 pickup in my 85. I tried putting the 88's front driveshaft on. Didn't fit, too short. Figured maybe there was a difference in length between IFS and SA. Swapped the 85's front driveshaft over to the manual trans. STILL too short.
WTF over? What am I doing wrong. The manual is shorter right? If anything shouldn't my front driveshaft be too long?
Old Jan 20, 2010 | 07:22 PM
toyotabull's Avatar
so you pulled the tranny from an ifs rig and put into a solid axle correct?
Old Jan 21, 2010 | 02:52 AM
203Cree's Avatar
Yes. And I put the solid axle front driveshaft back in and it's still too short.
I used the auto cross member if that matters. The manual mount stayed on the trans, and from what I found everyone says that's all that needs swapped.
Old Jan 28, 2010 | 05:18 PM
durtyrunner94's Avatar
that is weird because i did an sas and i used the 85 driveshaft that i got with the axle and i worked. needless to say the velocity joint was starting to go bad and finally got to bad so i switched it and put an 87 shaft in which works also for length i just had to grind a little out of where the u joints were hitting to get enough angle out of it
Old Feb 2, 2010 | 01:47 PM
203Cree's Avatar
Damn. I know that the the front isn't a slider type. Wonder what the problem is then.....
Old Feb 5, 2010 | 02:29 PM
203Cree's Avatar
Yeah, so nevermind. The front is a slider. The yoke was so covered it it wouldn't move, lol.
88sasturbotoy
Jan 30, 2026 01:57 PM
Jun 1, 2021 01:51 PM
deepmarsh
Aug 6, 2015 03:44 AM
jgwerth
Jul 16, 2015 03:23 PM
Steven.m.paulk
Jul 13, 2015 01:40 PM
