3" of hard lift... how does high-steer fit?
Old Jan 18, 2010 | 04:46 PM
hiltu's Avatar
Trail gear states that you need a minimum of 4" of lift in order for the drag link to clear the oil pan. I can't find any info on the all pro off road kit minimum lift requirements. I see a possible dropped pitman arm as a solution but i wanna see if anyone is sporting high-steer with 3" of lift or less. Thanks
Old Jan 18, 2010 | 05:14 PM
89silverpu's Avatar
Keep in mind that if you change the front spring hanger like one offered by TG and you put 3 inch springs on it then that will equate to 4" lift. Doesn't answer your question really, but it relates...
Old Jan 18, 2010 | 05:17 PM
ScottyC's Avatar
All-Pro, Marlin, and TG and most, if not all highsteer arms need 4". They are all built to just clear the springs, so they are all very similar and work in the same way.
What lift are you running?
Old Jan 18, 2010 | 10:36 PM
4x4YOTA's Avatar
Im running 2-2.5" of lift and running highsteer with a flat pitman arm and have no issues at all
Old Jan 21, 2010 | 01:59 AM
hiltu's Avatar
I have a 3" Rough Country lift. Right now i don't want to lift it anymore as its drives great. I don't want to screw with driveline angles and such. 4X4YOTA, im only concerned that maybe your geometry is a little different between your 81 and my 85. Just trying to think this out, won't a dropped pitman arm as well as mounting the steering box as low and as forward remedy this?
Old Jan 23, 2010 | 01:50 PM
hiltu's Avatar
Scotty, im running a 3" rough country lift. Also, now im reading that you need a 4" SUSPENSION lift, not lets say a 3" suspension lift and a 1" bodylift. Any chance for confirmation? thanks
Old Jan 23, 2010 | 01:59 PM
camo31_10.50's Avatar
there's a guy running around here and pirate that has designed a NEW crossover steering setup...and it actually looks like it will/has worked VERY VERY well, i'm sure one of the Veterans on here know who i'm talkin about
Old Jan 23, 2010 | 02:59 PM
hiltu's Avatar
any chance of a link??
Old Jan 23, 2010 | 09:51 PM
sadly no
i'm not SAS'd or have the intent of going SA so i didn't bookmark it or anything
Old Jan 24, 2010 | 02:27 AM
hiltu's Avatar
It all looks too expensive or too time consuming to get 1 more inch of suspension lift. Still looking for input. Maybe people can give me measurements with their 4" lifts and i can compare it with my 3" lift. Maybe the difference in settling could put me close enough to be willing to try the hy-steer kit. Just spec out distance from the ground to the center highest spot of the front fender, just make sure to include tire size. thanks
Old Jan 28, 2010 | 05:11 PM
ScottyC's Avatar
Body lift won't change the suspension height.
You could try the rough country lift. FWIW, I remember installing one on a either a Rough Country or Tuff country, but he ran a 5" shackle up front for the extra lift needed. It would give you around 3.75" of lift. So, it should work.
If fit, but was tight.
Old Jan 28, 2010 | 05:28 PM
durtyrunner94's Avatar
i am running more than 3 inches but there in a big hump on the bottom of the oil pan in the 3.0 that is really not needed. you can cut that hump off of the oil pan (if yours has it) and and weld a flat plate on it and that will solve yous prob
Old Jan 28, 2010 | 05:50 PM
Old Jan 28, 2010 | 06:51 PM
oh yeah and i didnt realize i was int the 84 85 forum till till a bit ago but you never know that may work for you also not sure though
JustMike
Apr 21, 2016 07:08 PM
rocket
Jan 21, 2016 05:03 PM
justdifferentials
Just Differentials
Sep 17, 2015 06:14 PM
greenbuggy
3.4 Swaps
Jul 23, 2015 11:51 AM
skoti89
Jul 8, 2015 12:05 AM
