running on 2 cylinders
Old Jan 23, 2010 | 09:39 AM
frankentoyota's Avatar
i just rebuilt my 22re motor. bottom end completely done. new pistons, crank turned, rods turned, bearings, etc. head was good when i put it all together. compression is good on all cylinders but its only running on cylinders 2 and 3. it is throwing code 12(knock sensor) which is new with a new ecu and sheilded wire. i also replaced plugs cap and wires and timed it all up. cant figure out why 1 and 4 wont fire.. any ideas?
Old Jan 23, 2010 | 11:27 AM
4Crawler's Avatar
See thread below:
- http://www.4x4wire.com/forums/showfl...rue#Post743055
Could be two of the injector connectors are not getting a connection to the ECU.
Old Jan 23, 2010 | 02:34 PM
ok i had it running alot better. couple of crappy injectors but had a leaky injector after the repair. took it apart again and fixed the leak now it running not very well again and is throwing a code 7. but no more code 12.. im lost on the throttle position sensor.. it idles fine and it just seems to rev up a little slow
Old Jan 23, 2010 | 02:39 PM
4Crawler's Avatar
Have you tested the TPS?
- http://www.4crawler.com/4x4/CheapTricks/TPS/index.shtml
Old Jan 25, 2010 | 06:25 PM
ok i have come to the conclusion that fuel is not being recieved to the number one and four cylinders. lost on that because i have swapped injectors out and the ohm reading on the injectors is all 3. no change. and according to my wiring diagram injector 1 and 2 are on a circuit and 3 and 4 a circuit and injectors 2 and 3 are fine so unless the wires are broke between the splice in the harness i cant see how its electrial.. is my diagram wrong or am i missing something or confused?? the more i search the more i find strange
Old Jan 29, 2010 | 07:21 AM
cruiserjohn's Avatar
bad connections
Had the same thing happen to me whem I did a timing chain replacement. It turned out to be the little plugs that goes on the injectors, one of the wires pushed up onto the connector and was not going onto the injector body .
Sleaker
Aug 26, 2020 06:03 AM
jasonty
41
Dec 23, 2018 01:00 PM
Doug4320
Mar 24, 2018 10:11 PM
Sep 4, 2015 09:27 AM
cars-guy
Jul 11, 2015 07:51 PM
