85 power window gremlin!!
Old Jan 8, 2010 | 08:42 PM
spideynut's Avatar
My 85 4x4 truck has a wierd power window problem. The pass. will roll down but not up (driver works). On both switches drive,pass. So I jumped the back of the pass. side switch and wham! the window went right up. Good we dont need a towel any more and bad cuase I had a $30 used motor in my hand.
I tried to clean the 2 switches with no luck, the switchs actully look nice when I took them apart. Any help whould be great. Brad
Old Jan 8, 2010 | 09:18 PM
4runnerRandy's Avatar
This happened to my 85 4runner also. I removed to switch and took it apart and bent the contacts back so that they were making positive contact with the switch. I found that after time the contacts lost their spring and no longer made proper contact and that it was a relatively easy repair. A switch was like 80 bucks used at the yota yard, they are hard to come buy. Good luck
Old Jan 9, 2010 | 05:41 PM
spideynut's Avatar
For the record it was the relay. Thanks to this web site I was able to bypass the relay and test the motor. And son of a gun it went up and down! Thanks for the help. Brad
Jun 1, 2021 01:51 PM
westonian18
May 1, 2020 06:38 AM
okamikai
Apr 30, 2018 10:19 PM
coreyedwards7611
Jan 16, 2016 06:38 PM
Johntom240
7
Jul 13, 2015 12:18 AM
